First post, by emendelson
emendelson
Offline
Someone in another thread asked how to run DOSBox from VisualBasic. The following VBS code does the job. Save as SomeFileName.vbs and run it:
Dim sCmdsCmd="d:\Full\Path\To\Dosbox.exe -noconsole"Set oShell = WScript.CreateObject("WScript.Shell")oShell.exec(sCmd)Set oShell=Nothing
The -noconsole switch is there only as an example; you can of course put in any switches you like or use the contents of a variable created earlier in the same script.
The final line isn't really necessary, but is useful if you're going to do anything else in the script.
