First post, by ratfink
I recently got a Deskpro EP. The front of the case has "Pentium III" on it, and inside it says K450/10.There's no graphics card but starting it up gives beeps so it's not dead at least. A sticker inside the case indicates jumper settings for cpu speeds and fsbs of 66 and 100. As yet I haven't put a graphics card in it, but it has 2 isa, 4 pci and an agp slot, so I'm supposing it's a bx board.
To be worth me using this, I'd want it to be faster, maybe around 700mhz to 1ghz. 750 is not listed as a viable cpu on this, though old postings on the web indicate this should be supported.
I was wondering if one of the oem gurus might know what the board is capable of?
