First post, by ryowa
Hi guys! 😀
I need to write some .asm code for school. Unfortunately I am running OS X Lion so I can't test if it works. I found DOSBox to be the best solution.
I downloaded necessary files here
http://dl.dropbox.com/u/5593269/aio2011.zip
I moved these files to my desired location.
Then I ran DOSBOx.
Then I "wrote mount c ~/Documents/School/IAS/allinone2011/"
Folder was mounted successfully.
Then I tried "run hello" but it didn't work. Can you tell me guys what am I doing wrong?
