First post, by j'ordos
Hi all,
I have problems connecting a win98se machine to a wireless network. I'm using an USB wireless stick (asus WL-167g). The network uses WPA encryption so I had to install the Mcafee Internet Security Suite which enables WPA support in win98. It can see the network and connect to it without problems, but actually opening a webpage does not work. I was able to connect to the internet using the same setup fine on a different network (though it often required restarting the pc a few times) but now it just won't work at all. WinIPcfg reports it didn't find a DHCP server. I have done a lot of searching already but I can't find a solution and I don't know what to do anymore. Does anyone have ideas on what I could do? Or how to enter the information manually?
Thanks in advance and let me know if there is more information you need!
