First post, by yifangt
Hello,
I installed DOSBOX in my Ubuntu 11.10, which seems working. But when I tried to run another DOS program within it, there was always an error saying:
DOS/4GW Fatal error: Can't find loader for file[1] --C:\mapmaker\mapbin.exe
But the file mapbin.exe is in the folder.
By the way, not sure why DOS/4GW is asking for loader when there is file DOS4GW.exe in the same folder.
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file /home/yifang/.dosbox/dosbox-0.74.conf
MIXER:Got different values from SDL: freq 44100, blocksize 512
ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)
MIDI:Opened device:none
DOSBox switched to max cycles, because of the setting: cycles=auto. If the game runs too fast try a fixed cycles amount in DOSBox's options.
I tried DOSBOX in my other laptop under linux Ubuntu11.10 for the same DOS program, which was fine. This PC is a desktop with Ubuntu11.10 server. Any clue for this problem? Thanks a lot!
Yifang
Reply 2 of 4, by yifangt
It was:
mount C: /home/yifang/mapmaker
where mapmaker is the folder to run the programs. Thanks again! Yifang
Reply 3 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Then it's clear. The settings of the app expect the mapbin.exe file to be in c:/mapmaker but the way you mounted it ends up in the root of c:
Mount c /home/yifang
C:
Cd mapmaker
Program/batchfile name
Should do it
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 4, by yifangt
Thanks a lot! YF
