Microleague Football 2
First post, by olddosuser
I downloaded Microleague Football2. I manged to install the game after playing with the label names (renaming them). The only problem is there is no audio. I have tried several different audio selections in the game, I also have Microleague Baseball 4 and the audio works in that game. It has the same install as the Football.
A separate question. I created an "A-drive" folder and mounted it to the A: drive. I then switch to A: drive in DosBos and the install/setup to install programs. How do I properly handle programs on multiple disks? I know about the label switch but can I change the name in the middle of an install to trick it into thinking I change the disks? I know it is simpler to copy all the files in the folder and hope that it does not ask for next disk(s), but that does not always work.
Thanks for creating DosBox, it has kept all my Dos apps/games alive.
Reply 1 of 1, by eL_PuSHeR
We do not support downloaded copies, sorry.
