Tillamook 266MHz and working L2 cache?
Reply 500 of 505, by Sphere478
Re: IDT Winchip 2A PR266 a.k.a "Weirdo"
Anyone have a functioning setup live at the moment for a test?
Sphere's PCB projects.
Reply 501 of 505, by JustJulião
Sphere478 wrote on 2024-02-27, 13:35:
I don't know what you want to test, but both the rig from the linked thread and one with a modded Tillamook on a MVP3 mb with cache are running here.
Reply 502 of 505, by Sphere478
JustJulião wrote on 2024-02-28, 18:51:
Was curious about the response from the chip when intel bf2 was pulled high. Changing bf0, bf1.
From what I recall, intel bf2 basically defaults to pull down when floating.
And when bf2 is pulled down bf0,1 provide 133-233 mhz options.
But when intel bf2 is pulled high the chip always is at 266 no matter what bf0,1 are set to.
If someone can verify that. Not with my setup atm.
Reply 503 of 505, by Sphere478
https://www.ebay.com/itm/176350362839
166mhz tillys spotted
    264.66 KiB
Reply 505 of 505, by Sphere478
Show picture of mods are, update, bios, have you verified the voltage is correct
