VOGONS Driver Library
Reply 640 of 1466, by gerwin
SquallStrife wrote:
gerwin wrote:
SquallStrife
It is not really important, but the text line-height is not entirely proper. Text can overlap the text below it. It has always been that way. I think if you just remove line-height styles it should correct itself. Using Firefox here.
I've implemented this, and it's fixed a lot of the layout problems I was seeing about the place. Cheers mate!
Great! It reads a lot better now. Thanks for remembering my remark, and good to see you managed to find time for maintenance on this very useful repository.
Reply 642 of 1466, by Whiskey
Just got this driver disc and manual in the post with a Turtle Beach Montego A3D 64 Voice PCI card (Aureal Vortex AU8820B2). I've created an ISO of the disc and a PDF of the manual.
Disc creation date is the 18th of March 1998 while most of the drivers files are defined as "Revision: 14, Date: 10/28/97". Disc label is 'MONTEGO' and contains setup folders for the following languages; Dutch, English, French, German, Japanese, Korean, Spanish, Swedish and Thai. Installer is for 9x and NT and seems to contain VXD and WDM drivers ver 4.0.1381.1
ISO (125.5MB) - https://drive.google.com/open?id=1Gng3tbs5O0K … CL3_z709AGDY_Vg
Manual - https://drive.google.com/open?id=19vw3f1CrQ94 … dV8BukWC2UzQA94
As the Vortex is not as popular as the Vortex II I thought this disc might be a good addition to the Vogon's driver database.
    1.62 MiB
    Turtle Beach Montego A3D 64 Voice PCI front
    1.18 MiB
    Turtle Beach Montego A3D 64 Voice PCI manual cover
    836.51 KiB
    Turtle Beach Montego A3D 64 Voice PCI disc cover
I stream retro games every wednesday here & I dump the recordings here
Reply 643 of 1466, by SEGamer
Matrox Mystique Installation CD
Iso - https://www.dropbox.com/s/ss0rfqceex9icrd/Mat … l%20CD.iso?dl=0
    175.95 KiB
    205.56 KiB
NintendoAge | VCFed
Reply 645 of 1466, by gerwin
Did you check this ISO for having parts with password protection, like the Montego II one?
See: Turtle Beach Montego II Unboxing
And: http://www.vogonsdrivers.com/getfile.php?fileid=1009
Reply 646 of 1466, by Whiskey
Hi Gerwin, I did not check for this as I didn't even know it was possible. Can you explain what you mean in more detail? Are some folders on the disc encrypted or do you mean something else? As far as I could tell the ISO I made is just a basic disc image with nothing special going on and the disc only contained drivers, no licensed software.
Hope this helps.
Reply 648 of 1466, by PunishedSnake
Hey SquallStrife and also DosFreak if you're out there, I'm posting here after speaking with Vlask, I'd come across a suspected VESA initialisation bug in pure DOS with the 3DFX Voodoo5 5500 PCI where most VESA applications would hang on a black screen, make my monitor wig out with invalid refresh rates indicated with an Out-of-Range error or show garbled graphics and artifacting which ended up being resolved by popping GAREPORT.EXE from SciTech SNAP for DOS within my AUTOEXEC.BAT.
After some digging around I came across a serial key within a text-file originating from SciTech themselves where they'd made the earlier OS/2 version freeware before selling it to the ecomstation devs.
Now just out of sheer curiosity I tried the OS/2 version key in the DOS version and it activates fine!
I think this would be great to have on the VOGONS Driver Library as a companion alongside the other SciTech Freeware releases, Below are archive.org links to the serial key text-file and to the respective installers for all the Operating Systems supported, unsure if it'll activate anything other than OS/2 and DOS but it might be worth a try.
OS/2 Version 3.1.8 Registration Code (works with 3.1.1 for DOS!)
https://web.archive.org/web/20130218195628/ht … ee-reg-code.txt
DOS Version 3.1.1
http://web.archive.org/web/*/http://www.scite … m/ftp/snap/dos/
Windows 2000/XP Version 3.1.4 DPVL beta2
http://web.archive.org/web/*/http://www.scite … nap/win2k/beta/
Windows NT 4.0 Version 3.1.1
http://web.archive.org/web/*/http://www.scite … /ftp/snap/winnt
Windows NT 4.0 Version 3.1.3 beta 1284
http://web.archive.org/web/*/http://www.scite … nap/winnt/beta/
IBM OS/2 (eCS) Version 3.1.8
http://web.archive.org/web/*/http://www.scite … m/ftp/snap/os2/
Reply 650 of 1466, by Dhigan
Hello SquallStrife,
Drivers for S3 Trio3D 1X/2X 5.30.05 for w2k and XP seem not to be in the VOGONS library (thanks for it by the way)
Can be downloaded from here :
https://www.touslesdrivers.com/index.php?v_pa … =23&v_code=9371
Win 3.1 : HP Omnibook 425 + Toshiba T2130CT
Win 9x : Dell Latitude Cpx H500GT + Dell GX1
Win XP64 : Asus P5B Xeon
Reply 651 of 1466, by cyclone3d
This is just a heads up that I uploaded the driver / application CD and CD label scans for the Yamaha SW1000XG sound card to vogonsdrivers.
http://www.vogonsdrivers.com/getfile.php?file … 469&menustate=0
It is also available from my XG resource repository in my sig.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 652 of 1466, by Salient
Would anyone be interested in (images of) these?
I recently dug these disks up from being stowed away.
Reply 653 of 1466, by elianda
I could run them through Kryoflux.
Youtube Channel
Reply 654 of 1466, by Beegle
Of course! I'm missing one of the RAP-10 disks, that would be of help. And the AdLib gold tools are quite rare.
I take it you own all those cards? Then this thead could interest you, and you could add your name to the google docs. List of rarest PC soundcards
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 655 of 1466, by Salient
As a matter of fact, I used to own these but sold them years ago. These disks are leftovers I recently found at the attic. I don't own many soundcards anymore, however I do own quite some midi modules and wavetable daugterboards.
Anyway, I'll make images of the disk sets and post them here.
Reply 656 of 1466, by xjas
Whiskey wrote:
Just got this driver disc and manual in the post with a Turtle Beach Montego A3D 64 Voice PCI card (Aureal Vortex AU8820B2). I'v […]
Dude, thanks for these! I'm setting up a PC with this exact card for some A3D sweetness.
Reply 659 of 1466, by ntalaec
Hi all,
I don't have account in the library page, so I think it's OK to post it here.
I have uploaded the following disks with scans of the floppies:
Included with Cirrus Logic GP-5446na-1.3 ctg5252-2:
Cirrus Logic GP-5446 CompCore SoftPEG Player
Cirrus Logic GP-5446 Display Driver V1.0 (2 disks)
Included with Dexxa 3b Mouse 851192-0000 m-cac64:
Dexxa-3 Button Mouse
Included with LG CD-ROM CRD-8522b 1.00:
LG CD-ROM Drive ver 1.26
Included with Sound Blaster 16 Pro npp49 CT2950:
Sound Blaster CD (spanish)
Sound Blaster Plug n Play Configuration Manager (spanish)
Download link (23 MB):
https://www.mediafire.com/file/k1wto0kevc61ri … rivers.zip/file
Edit: Reuploaded: 2 disks were in IMZ format instead of IMG
