First post, by desdrl
Hi, I can't ge DOS Box to run full screen in Win 7 64bit.
When I press ALT-Enter the screen goes black as if full screen but DOS Box is is centered in the middle of the screen same size as if running in windows mode. 😖
Any one got any suggestions?
Reply 1 of 1, by VileR
sure - check the readme and your .conf file about the "fullresolution=", "output=", "aspect=" and "scaler=" settings.
what you'll need to have there depends on your video card, video driver, monitor, and personal preference. So the provided explanations should have you good to go.
