First post, by swaaye
Post pics and comments about anything they've produced, up to Radeon R3x0.
ATi Radeon 9800 Pro with 256MB RAM
This showed up several months into the life of the 128MB version. It cost $450-500 at the time. There are a few different 256MB models.
This card uses the R350 GPU (9800 Pro) and early DDR2 memory. The RAM heatsinks are legitimately needed as the RAM runs very hot. The card's clock rates are 380 MHz core and 350 MHz RAM. I found that it can not be overclocked more than about 20 MHz on either RAM or core before artifacts show. Later 256MB models use R360 (9800XT) and DDR1 memory.
Notes:
-The thermal paste had long ago dried up and the GPU was overheating and unstable. ATi went cheap, apparently.
-The fan is very loud due to high RPM. I replaced it. 9700 Pro wasn't as loud.
-Radeon 9500/9700/9800 do not like AGP @ > 66 MHz.
-I like the brass pins used for the heatsink. Resilient.
Of course I ran Oblivion on it and it is several times faster than the 5900 Ultra. You can run the game on high detail at 1024x768 and enjoy it if you are ok with 10-20 fps. 800x600 is quite smooth. The 256MB RAM allows High detail textures to be usable since they consume about 256MB VRAM.
