Two questions.
First post, by dosquest
First, how much do you think a 128mb nvidia graphics card would bottleneck a pIII 500mhz with 512mb ram? Also, on the same note, the motherboard has jumpers that can control the cpu speed, now three is a spot for default (default cpu speed no change) 200mhz 250mhz 300 and 500mhz and 550mhz could I potentially set it to 1ghz by putting a jumper on the 500 and 550 spot? Or would that not work? The computer is a dell optiplex gx something.
Reply 1 of 9, by dosquest
Or another use is I could throw my sbpro and the 128mb into a dell tower that is 800mhz and put windows 2k on it.
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 2 of 9, by SquallStrife
We would need more info than the amount of VRAM to answer that question.
Reply 3 of 9, by leileilol
dosquest wrote:
128mb nvidia graphics card ......... pIII 500mhz with 512mb ram.....The computer is a dell optiplex gx something.
FX5200 in a Dell Optiplex GX110
Riser PCI only, so just forget it. You'd probably fry the Dell PSU.
Use a Voodoo3 PCI
As for the CPU jumper don't bother, it's the earliest Pentium III - you'd best get 667mhz from it in overclocks. The 1GHz P3's are from the much later cores
Reply 4 of 9, by dosquest
Thanks, just wanted to give it a slight boost, but thanks for the help. I should really get an avatar. 😒
Reply 5 of 9, by sliderider
Those Dell GX PSU's are only good for about 200-250W at best so you can't get carried away adding cards to them. There are harnesses you can buy that will convert an ATX power supply to a Dell proprietary so you can get increased power for adding upgrades or there are plans available online for making one yourself.
Reply 6 of 9, by Tetrium
True that, but this is one of the reasons I skip Dell and co altogether
My retro rigs (old topic)
Report spammers here!
Reply 7 of 9, by leileilol
even a S3 ViRGE can fry a Dell PSU...
Reply 8 of 9, by Tetrium
I'd feel more sorry for the Virge then that Dell PSU though 😜
Generally it's easier to just stick with standard ATX or AT gear, god I have a real dislike for proprietary stuff
Reply 9 of 9, by dosquest
Yeah, I didn't specifically pic the dell, I just kinda got it because it was cheap (free) and it had win98 (check out ALL my other threads for the fully saga of this computer.)
