First post, by pinkdonut666
so I'm building a P3 machine and wanted a CPU upgrade. I had a buddy with a Pentium 3 1000 he took out of a machine. (he sells parts and want's an excuses to upgrade from it) The machine was a dell XPS 650r with a P3 650, From what i can find in manuals, and online my mother board supports up-to a 1.1ghz slot 1 CPU. But when I put the CPU in (and yes I know it works!) I get a beep command and no bios. the beeps are 1-4-3-3 which isn't in my manual. the motherboards a dell OEM e139671.
my life runs on X86
Reply 1 of 19, by pinkdonut666
the original CPU was a 650
my life runs on X86
Reply 2 of 19, by pinkdonut666
I also get an "other failure" according to the boot lights.
my life runs on X86
Reply 3 of 19, by DonutKing
Firstly there is an edit button in the top right of your posts (just below the 're:' button of the previous post) which makes it easier to read that posting 3 times in a row 😀
Your problem is possibly due to the new CPU being a Tualatin core. These required lower voltage than the older Coppermine and Katmai cores. So not only does your BIOS need to recognise Tualatins, your motherboard has to electrically support them too.
However, to my knowledge the Tualatins were all Socket 370 processors while the Coppermines were available in both Slot 1 and Socket 370 of speeds up to 1.1GHz.
It's possible to get slot 1 -> socket 370 adapters, and if this is what you have then I'd say your processor is a Tualatin. Some adapters will allow Tualatins to run on older boards - some don't.
Can you post pictures of the processors including any numbers/text that might be on them?
Its also possible that your motherboard simply needs a BIOS update to recognise the newer Coppermine processor.
Reply 4 of 19, by pinkdonut666
I Know it needs a bios update now, don't know for sure if that will fix it though. IT SHOULD according to dell. And no it's not a 370 socket adaptor, it's a copermine 1000. I would post pics but It's being ass and won't let me. My bios is Two stages out of date, according to dell the update i download gave support for 1ghz+ cpu's but i need to get some 1.44mb disks to update it. all i have laying around are 360k and 720k disks.
my life runs on X86
Reply 5 of 19, by pinkdonut666
I was able to get my computer to let me post images it might take me a couple posts though. the only stuff on the cards is the speed and build date. the 650 from 99 and the 1000 from 00
my life runs on X86
Reply 6 of 19, by sliderider
Phoenix BIOS lists a 1-4-3-3 error code and the list of codes I have just says 'Autosize cache', nothing more, so at least that's a starting point.
Reply 7 of 19, by pinkdonut666
I Found the same thing and looked up "Autosize cache" too. I'm gonna have to update my bios and go from there. I posted this then spent hours searching around myself for an answer.
my life runs on X86
Reply 8 of 19, by eL_PuSHeR
[Thread moved to Marvin Section]
Reply 9 of 19, by megatron-uk
Is it a 10 x 100MHz or 7.5 x 133MHz cpu? your board may not support the 10x multiplier if it is the former.
https://www.target-earth.net
Reply 10 of 19, by maddmaxstar
PIII 650 only came in Coppermine-core form. So a 1GHz Coppermine should throretically work, however...
I'd go to http://www.cpu-world.com and search the CPU ID on the site by either it's SL number (ie: SL4BR) or ID code (ie: 80526PY1000256) and try to identify if it's a 10x100MHz or 7.5x133MHz FSB chip. A quick search on a Dell forum showed that the T650r may only support a 100MHz FSB chip, so it may not recognize the CPU properly if it's a 133 chip.
In any case, it also may not work without a BIOS update as well, so that may be worth trying first.
= Phenom II X6 1090T(HD4850) =
= K7-550(V3-3000) =
= K6-2+ 500(V3-2000) =
= Pentium 75 Gold(Voodoo1) =
= Am486DX4-120(3DXpression+) =
= TI486DLC-40(T8900D) =
= i386sx-16+i387(T8900D) =
Reply 11 of 19, by pinkdonut666
It's a 7.5 x 133 and the 650's a 6.5 x 100 I hope the bios update lets it support a 133
my life runs on X86
Reply 12 of 19, by luckybob
Its likely the motherboard does not support 133mhz fsb processors. 650mhz is COMMON as the fastest 100mhz chip you get. 850 is another "fastest possible" chip.
Reply 13 of 19, by pinkdonut666
I should be getting some HD disks so ic an test if the update dose what the sparse description says "lets A05 to A07 users upgrade BIOS for faster CPU replacements." All i have is a brand new box of 2DD disks. NOT BIG ENOUGH it says, I thought a 470kb program could fit on a 720kb diskette... But who am I to Judge Dell and there all powerful holy-ness... ...
my life runs on X86
Reply 14 of 19, by noshutdown
man there are pentium3 1ghz and 1.1ghz with coppermine core and 100fsb. 😒
its not very easy to find though, i also want one to run on my bx platform.
Reply 15 of 19, by luckybob
noshutdown wrote:
luckybob wrote:
Its likely the motherboard does not support 133mhz fsb processors. 600mhz is COMMON as the fastest 100mhz chip you get. 850 is another "fastest possible" chip.
I meant common speed walls. 600mhz was the fastest first gen p3 made. It came with 512kb of cache. A LOT of systems stopped at 850 mhz. I don't know the details off-hand, but there was a shift in coppermine cache and some boards didn't support it.
Reply 16 of 19, by maddmaxstar
Not only that but Dell was also notorious for programming only the strings for the CPUs they want you to upgrade to in the BIOS. For example, systems with that Motherboard may have came with a 650, the fastest they sold in their upgrade store may have been a 750 (just an example), nothing faster will work by design.
Anyway, I work for a PC store that does recycling, I'll keep my eyes peeled for a faster PIII, but can't promise anything.
= K7-550(V3-3000) =
Reply 17 of 19, by sliderider
Yup. My Dell GX1's have this issue. You can only use BIOS versions up to A7 if you want to be able to use the fastest P-III's in them. Anything after that and they hobble your upgrade options to about 600mhz.
Reply 18 of 19, by gerwin
Such a policy just motivates unofficial BIOS modifications. My main retro Slot-1 system also uses an unofficial BIOS to support Tualatin core P-III processors.
Reply 19 of 19, by Tetrium
It also motivates in using standard equipment instead of using Dells.
I personally avoid anything that can't use a standard PSU and a standard AT(X) case.
My retro rigs (old topic)
Report spammers here!
