First post, by shorty
Hi ...
i want to shortcut a batchfile that starts dosbox and a command
content of batchfile:
C:\DOSBox-0.74\DOSBox.exe -conf df.conf -noconsole -exit "c:\dagger\fall z.cfg"
i could write it in my conf file , but i want to have a desktop link without starting dosbox manually ... so i can give it an ico ...
any suggestions?
or must i create a new conf file with
[autoexec]
Greetings ...
multiplayer? ranking.php?id=7
Reply 1 of 9, by Davros
create file with notepad
save it as vogons.bat (not vogons.bat.txt)
right click on it select create shortcut
right click on shortcut select properties -- shortcut -- select icon
job done
Reply 3 of 9, by Mau1wurf1977
Hmm this doesn't look right.
AFAIK you:
1. Create a shortcut of DOSBOX.EXE
2. Edit the properties of that shortcut and add -conf df.conf -noconsole -exit "c:\dagger\fall z.cfg"
Plan B is more complicated, but does what you're after:
1. Create and test the batch file
2. Use a BAT to EXE utility
3. Extract and inject an icon
4. Built the EXE
I used option B in order to build a portable Version of ScummVM that uses relative paths for all the folders. But this shouldn't be necessary with DOSBox.
My YouTube channel
Reply 5 of 9, by shorty
thank you so far
in linux i made shellscript using "-c command" and created a link to application ...
#/bin/bash
dosbox -c "c:\dagger\dagger~1.bat" -noconsole -exit -fullscreen
    878 Bytes
Reply 6 of 9, by jmcinvale
Probably the easiest way to do this is to use a program called dosshell http://www.loonies.narod.ru/dosshell.htm
It is a front end for DOSbox and makes playing DOS games as easy as clicking on the game's icon from within the DOSShell program.
Reply 7 of 9, by collector
Except that he is using Linux.
