When building yhkwong's build. I get these
First post, by lucky7456969
Warning	1	warning LNK4075: ignoring '/EDITANDCONTINUE' due to '/INCREMENTAL:NO' specification	dosbox.obj	dosbox
Warning 2 warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library dosbox dosbox
Warning 3 warning LNK4098: defaultlib 'msvcrt.lib' conflicts with use of other libs; use /NODEFAULTLIB:library MSVCRTD.lib dosbox
Error 4 error LNK2019: unresolved external symbol "public: void __thiscall SaveState::save(unsigned int)" (?save@SaveState@@QAEXI@Z) referenced in function "void __cdecl `anonymous namespace'::SaveGameState(bool)" (?SaveGameState@?A0x4d8293bc@@YAX_N@Z) dosbox.obj dosbox
Error 5 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) ems.obj dosbox
Error 6 error LNK2019: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) referenced in function "unsigned int __cdecl XMS_Handler(void)" (?XMS_Handler@@YAIXZ) xms.obj dosbox
Error 7 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) int10.obj dosbox
Error 8 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) fpu.obj dosbox
Error 9 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) memory.obj dosbox
Error 10 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) timer.obj dosbox
Error 11 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) vga.obj dosbox
Error 12 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) vga_memory.obj dosbox
Error 13 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) dma.obj dosbox
Error 14 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) iohandler.obj dosbox
Error 15 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) joystick.obj dosbox
Error 16 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) keyboard.obj dosbox
Error 17 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) dosbox.obj dosbox
Error 18 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) cpu.obj dosbox
Error 19 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) dos_files.obj dosbox
Error 20 error LNK2001: unresolved external symbol "public: static class SaveState & __cdecl SaveState::instance(void)" (?instance@SaveState@@SAAAV1@XZ) cmos.obj dosbox
Error 21 error LNK2019: unresolved external symbol "public: void __thiscall SaveState::load(unsigned int)const " (?load@SaveState@@QBEXI@Z) referenced in function "void __cdecl `anonymous namespace'::LoadGameState(bool)" (?LoadGameState@?A0x4d8293bc@@YAX_N@Z) dosbox.obj dosbox
Error 22 error LNK2019: unresolved external symbol "public: bool __thiscall SaveState::isEmpty(unsigned int)const " (?isEmpty@SaveState@@QBE_NI@Z) referenced in function "void __cdecl `anonymous namespace'::NextSaveSlot(bool)" (?NextSaveSlot@?A0x4d8293bc@@YAX_N@Z) dosbox.obj dosbox
Error 23 error LNK2019: unresolved external symbol "void __cdecl NE2K_Init(class Section *)" (?NE2K_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 24 error LNK2019: unresolved external symbol "void __cdecl GLIDE_Init(class Section *)" (?GLIDE_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 25 error LNK2019: unresolved external symbol "void __cdecl PARALLEL_Init(class Section *)" (?PARALLEL_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 26 error LNK2019: unresolved external symbol "void __cdecl PRINTER_Init(class Section *)" (?PRINTER_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 27 error LNK2019: unresolved external symbol "void __cdecl PS1SOUND_Init(class Section *)" (?PS1SOUND_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 28 error LNK2019: unresolved external symbol "void __cdecl INNOVA_Init(class Section *)" (?INNOVA_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 29 error LNK2019: unresolved external symbol "void __cdecl VOODOO_Init(class Section *)" (?VOODOO_Init@@YAXPAVSection@@@Z) referenced in function "void __cdecl DOSBOX_Init(void)" (?DOSBOX_Init@@YAXXZ) dosbox.obj dosbox
Error 30 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) xms.obj dosbox
Error 31 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) int10.obj dosbox
Error 32 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) fpu.obj dosbox
Error 33 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) timer.obj dosbox
Error 34 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) vga.obj dosbox
Error 35 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) vga_memory.obj dosbox
Error 36 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) ems.obj dosbox
Error 37 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) iohandler.obj dosbox
Error 38 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) joystick.obj dosbox
Error 39 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) keyboard.obj dosbox
Error 40 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) memory.obj dosbox
Error 41 error LNK2019: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) referenced in function "public: __thiscall SerializeGlobalPOD::SerializeGlobalPOD(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (??0SerializeGlobalPOD@@QAE@ABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) cpu.obj dosbox
Error 42 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) dos_files.obj dosbox
Error 43 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) cmos.obj dosbox
Error 44 error LNK2001: unresolved external symbol "public: void __thiscall SaveState::registerComponent(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,struct SaveState::Component &)" (?registerComponent@SaveState@@QAEXABV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AAUComponent@1@@Z) dma.obj dosbox
Error 45 error LNK2001: unresolved external symbol "class CParallel * * parallelPortObjects" (?parallelPortObjects@@3PAPAVCParallel@@A) dos.obj dosbox
Error 46 error LNK2001: unresolved external symbol "class CParallel * * parallelPortObjects" (?parallelPortObjects@@3PAPAVCParallel@@A) dos_devices.obj dosbox
Error 47 error LNK2001: unresolved external symbol "class CParallel * * parallelPortObjects" (?parallelPortObjects@@3PAPAVCParallel@@A) bios.obj dosbox
Error 48 error LNK2019: unresolved external symbol "public: __thiscall physfsDrive::physfsDrive(char const *,unsigned short,unsigned char,unsigned short,unsigned short,unsigned char)" (??0physfsDrive@@QAE@PBDGEGGE@Z) referenced in function "public: virtual void __thiscall MOUNT::Run(void)" (?Run@MOUNT@@UAEXXZ) dos_programs.obj dosbox
Error 49 error LNK2019: unresolved external symbol "public: __thiscall physfscdromDrive::physfscdromDrive(char,char const *,unsigned short,unsigned char,unsigned short,unsigned short,unsigned char,int &)" (??0physfscdromDrive@@QAE@DPBDGEGGEAAH@Z) referenced in function "public: virtual void __thiscall MOUNT::Run(void)" (?Run@MOUNT@@UAEXXZ) dos_programs.obj dosbox
Error 50 error LNK2001: unresolved external symbol "char * hdd_size" (?hdd_size@@3PADA) dos_programs.obj dosbox
Error 51 error LNK2019: unresolved external symbol "void __cdecl GetDefaultSize(void)" (?GetDefaultSize@@YAXXZ) referenced in function "public: virtual void __thiscall MOUNT::Run(void)" (?Run@MOUNT@@UAEXXZ) dos_programs.obj dosbox
Error 52 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) dos_programs.obj dosbox
Error 53 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) sdl_gui.obj dosbox
Error 54 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) sdl_mapper.obj dosbox
Error 55 error LNK2001: unresolved external symbol "struct MENU_Block menu" (?menu@@3UMENU_Block@@A) sdlmain.obj dosbox
Error 56 error LNK2001: unresolved external symbol "class Voodoo_PageHandler * voodoo_pagehandler" (?voodoo_pagehandler@@3PAVVoodoo_PageHandler@@A) memory.obj dosbox
Error 57 error LNK2001: unresolved external symbol "struct GLIDE_Block glide" (?glide@@3UGLIDE_Block@@A) memory.obj dosbox
Error 58 error LNK2019: unresolved external symbol "struct GLIDE_Block glide" (?glide@@3UGLIDE_Block@@A) referenced in function "void __cdecl DOSBox_SetIcon(void)" (?DOSBox_SetIcon@@YAXXZ) sdlmain.obj dosbox
Error 59 error LNK2019: unresolved external symbol "void __cdecl Voodoo_PCI_Enable(bool)" (?Voodoo_PCI_Enable@@YAX_N@Z) referenced in function "void __cdecl write_pci(unsigned int,unsigned int,unsigned int)" (?write_pci@@YAXIII@Z) pci_bus.obj dosbox
Error 60 error LNK2019: unresolved external symbol "void __cdecl HWOPL_Cleanup(void)" (?HWOPL_Cleanup@@YAXXZ) referenced in function "void __cdecl SBLASTER_ShutDown(class Section *)" (?SBLASTER_ShutDown@@YAXPAVSection@@@Z) sblaster.obj dosbox
Show last 60 lines
Error	61	error LNK2019: unresolved external symbol "void __cdecl HARDOPL_Init(unsigned int,unsigned int,bool)" (?HARDOPL_Init@@YAXII_N@Z) referenced in function "public: __thiscall SBLASTER::SBLASTER(class Section *)" (??0SBLASTER@@QAE@PAVSection@@@Z)	sblaster.obj	dosbox
Error 62 error LNK2019: unresolved external symbol __imp__fluid_set_log_function referenced in function _fluid_log_config midi.obj dosbox
Error 63 error LNK2019: unresolved external symbol __imp__fluid_default_log_function referenced in function _fluid_log_config midi.obj dosbox
Error 64 error LNK2019: unresolved external symbol __imp__fluid_midi_event_set_sysex referenced in function _fluid_midi_parser_parse midi.obj dosbox
Error 65 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::setDACInputMode(enum MT32Emu::DACInputMode)" (?setDACInputMode@Synth@MT32Emu@@QAEXW4DACInputMode@2@@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 66 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::setReverbOverridden(bool)" (?setReverbOverridden@Synth@MT32Emu@@QAEX_N@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 67 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::writeSysex(unsigned char,unsigned char const *,unsigned int)" (?writeSysex@Synth@MT32Emu@@QAEXEPBEI@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 68 error LNK2019: unresolved external symbol "public: bool __thiscall MT32Emu::Synth::open(struct MT32Emu::SynthProperties &)" (?open@Synth@MT32Emu@@QAE_NAAUSynthProperties@2@@Z) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 69 error LNK2019: unresolved external symbol "public: __thiscall MT32Emu::Synth::Synth(void)" (??0Synth@MT32Emu@@QAE@XZ) referenced in function "public: virtual bool __thiscall MidiHandler_mt32::Open(char const *)" (?Open@MidiHandler_mt32@@UAE_NPBD@Z) midi.obj dosbox
Error 70 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::render(short *,unsigned int)" (?render@Synth@MT32Emu@@QAEXPAFI@Z) referenced in function "void __cdecl MT32_CallBack(unsigned int)" (?MT32_CallBack@@YAXI@Z) midi.obj dosbox
Error 71 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::close(void)" (?close@Synth@MT32Emu@@QAEXXZ) referenced in function "public: virtual void __thiscall MidiHandler_mt32::Close(void)" (?Close@MidiHandler_mt32@@UAEXXZ) midi.obj dosbox
Error 72 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::playMsg(unsigned int)" (?playMsg@Synth@MT32Emu@@QAEXI@Z) referenced in function "public: virtual void __thiscall MidiHandler_mt32::PlayMsg(unsigned char *)" (?PlayMsg@MidiHandler_mt32@@UAEXPAE@Z) midi.obj dosbox
Error 73 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::playSysexWithoutFraming(unsigned char const *,unsigned int)" (?playSysexWithoutFraming@Synth@MT32Emu@@QAEXPBEI@Z) referenced in function "public: virtual void __thiscall MidiHandler_mt32::PlaySysex(unsigned char *,unsigned int)" (?PlaySysex@MidiHandler_mt32@@UAEXPAEI@Z) midi.obj dosbox
Error 74 error LNK2019: unresolved external symbol "public: void __thiscall MT32Emu::Synth::playSysex(unsigned char const *,unsigned int)" (?playSysex@Synth@MT32Emu@@QAEXPBEI@Z) referenced in function "public: virtual void __thiscall MidiHandler_mt32::PlaySysex(unsigned char *,unsigned int)" (?PlaySysex@MidiHandler_mt32@@UAEXPAEI@Z) midi.obj dosbox
Error 75 error LNK2019: unresolved external symbol "public: __thiscall MT32Emu::Synth::~Synth(void)" (??1Synth@MT32Emu@@QAE@XZ) referenced in function "public: void * __thiscall MT32Emu::Synth::`scalar deleting destructor'(unsigned int)" (??_GSynth@MT32Emu@@QAEPAXI@Z) midi.obj dosbox
Error 76 error LNK2019: unresolved external symbol __imp__new_fluid_midi_router referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 77 error LNK2019: unresolved external symbol __imp__fluid_synth_handle_midi_event referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 78 error LNK2019: unresolved external symbol __imp__delete_fluid_synth referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 79 error LNK2019: unresolved external symbol __imp__fluid_synth_sfload referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 80 error LNK2019: unresolved external symbol __imp__delete_fluid_settings referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 81 error LNK2019: unresolved external symbol __imp__new_fluid_synth referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 82 error LNK2019: unresolved external symbol __imp__fluid_settings_setnum referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 83 error LNK2019: unresolved external symbol __imp__fluid_settings_setstr referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 84 error LNK2019: unresolved external symbol __imp__new_fluid_settings referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 85 error LNK2019: unresolved external symbol __imp__fluid_synth_write_s16 referenced in function "void __cdecl synth_CallBack(unsigned int)" (?synth_CallBack@@YAXI@Z) midi.obj dosbox
Error 86 error LNK2019: unresolved external symbol __imp__delete_fluid_midi_router referenced in function "public: virtual void __thiscall MidiHandler_synth::Close(void)" (?Close@MidiHandler_synth@@UAEXXZ) midi.obj dosbox
Error 87 error LNK2019: unresolved external symbol __imp__fluid_midi_router_handle_midi_event referenced in function "public: virtual void __thiscall MidiHandler_synth::PlayMsg(unsigned char *)" (?PlayMsg@MidiHandler_synth@@UAEXPAE@Z) midi.obj dosbox
Error 88 error LNK2019: unresolved external symbol "struct HWND__ * __cdecl GetHWND(void)" (?GetHWND@@YAPAUHWND__@@XZ) referenced in function "void __cdecl UI_Shortcut(int)" (?UI_Shortcut@@YAXH@Z) sdl_gui.obj dosbox
Error 89 error LNK2001: unresolved external symbol "struct HWND__ * __cdecl GetHWND(void)" (?GetHWND@@YAPAUHWND__@@XZ) sdl_mapper.obj dosbox
Error 90 error LNK2001: unresolved external symbol "struct HWND__ * __cdecl GetHWND(void)" (?GetHWND@@YAPAUHWND__@@XZ) sdlmain.obj dosbox
Error 91 error LNK2019: unresolved external symbol "void __cdecl DOSBox_RefreshMenu(void)" (?DOSBox_RefreshMenu@@YAXXZ) referenced in function "void __cdecl MAPPER_RunInternal(void)" (?MAPPER_RunInternal@@YAXXZ) sdl_mapper.obj dosbox
Error 92 error LNK2001: unresolved external symbol "void __cdecl DOSBox_RefreshMenu(void)" (?DOSBox_RefreshMenu@@YAXXZ) sdlmain.obj dosbox
Error 93 error LNK2019: unresolved external symbol "void __cdecl GLIDE_ResetScreen(bool)" (?GLIDE_ResetScreen@@YAX_N@Z) referenced in function "void __cdecl GFX_ResetScreen(void)" (?GFX_ResetScreen@@YAXXZ) sdlmain.obj dosbox
Error 94 error LNK2019: unresolved external symbol "public: long __thiscall CDirect3D::Resize3DEnvironment(unsigned int,unsigned int,unsigned int,unsigned int,bool)" (?Resize3DEnvironment@CDirect3D@@QAEJIIII_N@Z) referenced in function "unsigned int __cdecl GFX_SetSize(unsigned int,unsigned int,unsigned int,double,double,void (__cdecl*)(enum GFX_CallBackFunctions_t))" (?GFX_SetSize@@YAIIIINNP6AXW4GFX_CallBackFunctions_t@@@Z@Z) sdlmain.obj dosbox
Error 95 error LNK2019: unresolved external symbol "public: long __thiscall CDirect3D::LoadPixelShader(char const *,double,double)" (?LoadPixelShader@CDirect3D@@QAEJPBDNN@Z) referenced in function "unsigned int __cdecl GFX_SetSize(unsigned int,unsigned int,unsigned int,double,double,void (__cdecl*)(enum GFX_CallBackFunctions_t))" (?GFX_SetSize@@YAIIIINNP6AXW4GFX_CallBackFunctions_t@@@Z@Z) sdlmain.obj dosbox
Error 96 error LNK2019: unresolved external symbol "void __cdecl DOSBox_CheckOS(int &,int &,int &)" (?DOSBox_CheckOS@@YAXAAH00@Z) referenced in function "void __cdecl SDLScreen_Reset(void)" (?SDLScreen_Reset@@YAXXZ) sdlmain.obj dosbox
Error 97 error LNK2019: unresolved external symbol "void __cdecl SetVal(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?SetVal@@YAXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V12@0@Z) referenced in function "void __cdecl change_output(int)" (?change_output@@YAXH@Z) sdlmain.obj dosbox
Error 98 error LNK2019: unresolved external symbol "public: long __thiscall CDirect3D::InitializeDX(struct HWND__ *,bool)" (?InitializeDX@CDirect3D@@QAEJPAUHWND__@@_N@Z) referenced in function "void __cdecl d3d_init(void)" (?d3d_init@@YAXXZ) sdlmain.obj dosbox
Error 99 error LNK2019: unresolved external symbol "private: void __thiscall CDirect3D::DestroyD3D(void)" (?DestroyD3D@CDirect3D@@AAEXXZ) referenced in function "public: __thiscall CDirect3D::~CDirect3D(void)" (??1CDirect3D@@QAE@XZ) sdlmain.obj dosbox
Error 100 error LNK2019: unresolved external symbol "void __cdecl DOSBox_NoMenu(void)" (?DOSBox_NoMenu@@YAXXZ) referenced in function "void __cdecl openglhq_init(void)" (?openglhq_init@@YAXXZ) sdlmain.obj dosbox
Error 101 error LNK2019: unresolved external symbol "public: bool __thiscall CDirect3D::LockTexture(unsigned char * &,unsigned int &)" (?LockTexture@CDirect3D@@QAE_NAAPAEAAI@Z) referenced in function "bool __cdecl GFX_StartUpdate(unsigned char * &,unsigned int &)" (?GFX_StartUpdate@@YA_NAAPAEAAI@Z) sdlmain.obj dosbox
Error 102 error LNK2019: unresolved external symbol "public: bool __thiscall CDirect3D::UnlockTexture(unsigned short const *)" (?UnlockTexture@CDirect3D@@QAE_NPBG@Z) referenced in function "void __cdecl GFX_EndUpdate(unsigned short const *)" (?GFX_EndUpdate@@YAXPBG@Z) sdlmain.obj dosbox
Error 103 error LNK2019: unresolved external symbol "void __cdecl MountDrive_2(char,char const * const,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?MountDrive_2@@YAXDQBDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl OpenFileDialog(char *)" (?OpenFileDialog@@YAXPAD@Z) sdlmain.obj dosbox
Error 104 error LNK2019: unresolved external symbol "bool __cdecl DOSBox_Kor(void)" (?DOSBox_Kor@@YA_NXZ) referenced in function "void __cdecl OpenFileDialog(char *)" (?OpenFileDialog@@YAXPAD@Z) sdlmain.obj dosbox
Error 105 error LNK2019: unresolved external symbol "void __cdecl Mount_Zip(char,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?Mount_Zip@@YAXDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl OpenFileDialog_Img(char)" (?OpenFileDialog_Img@@YAXD@Z) sdlmain.obj dosbox
Error 106 error LNK2019: unresolved external symbol "void __cdecl Mount_Img(char,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?Mount_Img@@YAXDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl OpenFileDialog_Img(char)" (?OpenFileDialog_Img@@YAXD@Z) sdlmain.obj dosbox
Error 107 error LNK2019: unresolved external symbol "void __cdecl mem_conf(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,int)" (?mem_conf@@YAXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 108 error LNK2019: unresolved external symbol "void __cdecl BrowseFolder(char,class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)" (?BrowseFolder@@YAXDV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 109 error LNK2019: unresolved external symbol "void __cdecl MountDrive(char,char const * const)" (?MountDrive@@YAXDQBD@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 110 error LNK2019: unresolved external symbol "void __cdecl UnMount(int)" (?UnMount@@YAXH@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 111 error LNK2019: unresolved external symbol "void __cdecl ToggleMenu(bool)" (?ToggleMenu@@YAX_N@Z) referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 112 error LNK2019: unresolved external symbol _closedir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 113 error LNK2019: unresolved external symbol _readdir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 114 error LNK2019: unresolved external symbol _opendir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 115 error LNK2001: unresolved external symbol "unsigned int hdd_defsize" (?hdd_defsize@@3IA) sdlmain.obj dosbox
Error 116 error LNK2019: unresolved external symbol "void __cdecl DOSBox_SetMenu(void)" (?DOSBox_SetMenu@@YAXXZ) referenced in function _SDL_main sdlmain.obj dosbox
Error 117 error LNK2019: unresolved external symbol "public: void __thiscall CParallel::initialize(void)" (?initialize@CParallel@@QAEXXZ) referenced in function "unsigned int __cdecl INT17_Handler(void)" (?INT17_Handler@@YAIXZ) bios.obj dosbox
Error 118 error LNK2019: unresolved external symbol "public: unsigned char __thiscall CParallel::getPrinterStatus(void)" (?getPrinterStatus@CParallel@@QAEEXZ) referenced in function "unsigned int __cdecl INT17_Handler(void)" (?INT17_Handler@@YAIXZ) bios.obj dosbox
Error 119 fatal error LNK1120: 77 unresolved externals .\Debug/dosbox.exe dosbox
Any ideas how to solve 'em
Thanks
Jack
Reply 1 of 23, by wd
Rank DOSBox Author
DOSBox Author
This forum is not intended for compile instructions with custom developer sources.
Reply 3 of 23, by leileilol
make sdl
long live PCem
Debian's fucked
Reply 4 of 23, by lucky7456969
Wondering where can I get the development version of SDL Sound.
Everything is fine now, except a little single line of error complaining about Sound_GetDuration.
Thanks
Jack
Reply 6 of 23, by lucky7456969
Sadly, When I undefine C_SDL_Sound, the error message still comes up
Thanks
Jack
Reply 8 of 23, by lucky7456969
I am using VS2008, how can this destiny be changed?
Thanks
Jack
Reply 9 of 23, by ykhwong
Set your configuration to Release, not Debug.
Also, you can revert the following code from mp3cue patch.
--- orig-src/dos/cdrom_image.cpp	2006-05-18 17:04:17.453125000 -0500
+++ src/dos/cdrom_image.cpp 2006-05-30 22:19:51.356301600 -0500
@@ -23,7 +23,6 @@
#include <fstream>
#include <iostream>
#include <limits>
-#include <limits.h> //GCC 2.95
#include <sstream>
#include <vector>
#include <sys/stat.h>
@@ -107,21 +106,8 @@
int CDROM_Interface_Image::AudioFile::getLength()
- int time = 1;
- int shift = 0;
- if (!(sample->flags & SOUND_SAMPLEFLAG_CANSEEK)) return -1;
- while (true) {
- int success = Sound_Seek(sample, (unsigned int)(shift + time));
- if (!success) {
- if (time == 1) return lround((double)shift * 176.4f);
- shift += time >> 1;
- time = 1;
- } else {
- if (time > ((numeric_limits<int>::max() - shift) / 2)) return -1;
- time = time << 1;
+ int length = Sound_GetDuration(sample);
+ return floor((double)length * 176.4f + 0.5f);
#endif
@@ -294,10 +280,16 @@
int track = GetTrack(sector) - 1;
if (track < 0) return false;
- int seek = tracks[track].skip + (sector - tracks[track].start) * tracks[track].sectorSize;
- int length = (raw ? RAW_SECTOR_SIZE : COOKED_SECTOR_SIZE);
if (tracks[track].sectorSize != RAW_SECTOR_SIZE && raw) return false;
+ int length = (raw ? RAW_SECTOR_SIZE : COOKED_SECTOR_SIZE);
+ if (sector >= tracks[track].start + tracks[track].length) {
+ memset(buffer, 0, length);
+ return true;
+ int seek = tracks[track].skip + (sector - tracks[track].start) * tracks[track].sectorSize;
if (tracks[track].sectorSize == RAW_SECTOR_SIZE && !tracks[track].mode2 && !raw) seek += 16;
if (tracks[track].mode2 && !raw) seek += 24;
Reply 10 of 23, by lucky7456969
Thanks, ykhwong, that's so kind of you
Reply 11 of 23, by lucky7456969
Beg your pardon, I wonder how to to use patch to patch the source code on hand.
been Googling and found nothing useful.
Thanks
Jack
Reply 14 of 23, by ykhwong
mp3cue patch is already applied to the source. So you have to get rid of it in order to remove SDL_sound dependency. This is diff that you can revert the patch.
patch binary is here.
http://gnuwin32.sourceforge.net/packages/patch.htm
In your source directory type
patch -up1 < revert.diff
Reply 15 of 23, by lucky7456969
I am sorry, Just can't handle this. After trying all your suggestions, the link time errors occur again.
I have set Sound_GetDuration to 0, so I can prevent that compile error from happening. However, the OP link time errors are still there.
Thanks
Jack
Reply 16 of 23, by lucky7456969
Hi ykhwong,
Thanks for coming back for help.
I am patching your code now. But there is only a blank screen when patching.
Does it take really long to finish?
Thanks
Jack
Reply 17 of 23, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You can also do it manually. When you look at the patch you want to revert, delete the lines with + and add back the lines with - (without the - of course).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 18 of 23, by lucky7456969
Funny though, is that savestate has caused some link time errors on my copy here.
I find out that MENU_Block has an extern but never actually defined. Why?
147 link time errors so far
Any ideas why?
Thanks
Reply 19 of 23, by lucky7456969
Error	13	error LNK2019: unresolved external symbol __imp__fluid_set_log_function referenced in function _fluid_log_config	midi.obj	dosbox
Error 14 error LNK2019: unresolved external symbol __imp__fluid_default_log_function referenced in function _fluid_log_config midi.obj dosbox
Error 15 error LNK2019: unresolved external symbol __imp__fluid_midi_event_set_sysex referenced in function _fluid_midi_parser_parse midi.obj dosbox
Error 16 error LNK2019: unresolved external symbol __imp__new_fluid_midi_router referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 17 error LNK2019: unresolved external symbol __imp__fluid_synth_handle_midi_event referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 18 error LNK2019: unresolved external symbol __imp__delete_fluid_synth referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 19 error LNK2019: unresolved external symbol __imp__fluid_synth_sfload referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 20 error LNK2019: unresolved external symbol __imp__delete_fluid_settings referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 21 error LNK2019: unresolved external symbol __imp__new_fluid_synth referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 22 error LNK2019: unresolved external symbol __imp__fluid_settings_setnum referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 23 error LNK2019: unresolved external symbol __imp__fluid_settings_setstr referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 24 error LNK2019: unresolved external symbol __imp__new_fluid_settings referenced in function "public: virtual bool __thiscall MidiHandler_synth::Open(char const *)" (?Open@MidiHandler_synth@@UAE_NPBD@Z) midi.obj dosbox
Error 25 error LNK2019: unresolved external symbol __imp__fluid_synth_write_s16 referenced in function "void __cdecl synth_CallBack(unsigned int)" (?synth_CallBack@@YAXI@Z) midi.obj dosbox
Error 26 error LNK2019: unresolved external symbol __imp__delete_fluid_midi_router referenced in function "public: virtual void __thiscall MidiHandler_synth::Close(void)" (?Close@MidiHandler_synth@@UAEXXZ) midi.obj dosbox
Error 27 error LNK2019: unresolved external symbol __imp__fluid_midi_router_handle_midi_event referenced in function "public: virtual void __thiscall MidiHandler_synth::PlayMsg(unsigned char *)" (?PlayMsg@MidiHandler_synth@@UAEXPAE@Z) midi.obj dosbox
Error 28 error LNK2019: unresolved external symbol _closedir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 29 error LNK2019: unresolved external symbol _readdir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
Error 30 error LNK2019: unresolved external symbol _opendir referenced in function "void __cdecl MSG_Loop(void)" (?MSG_Loop@@YAXXZ) sdlmain.obj dosbox
I sort of narrow down the range of errors.
There are 2 things I couldn't achieve.
1) Can't find dirent.h (POSIX header and libraries)
2) the file structure in fluidsynth seems to be corrupted. It couldn't find the .c file even I setup their correct paths.
Any help please?
Thanks
Jack
