Know any good ms-dos GUIs?
First post, by dosquest
Do not say win...ect I tried dosstart, also opengem I want something simple, but good, like the amiga gui but for ms-dos.
Reply 2 of 31, by DonutKing
Quikmenu 3 is what I use. Supports windows 16-color icons, very light memory footprint and has some fairly flexible scripting options too 😀
Reply 3 of 31, by keropi
there is nothing like workbench on DOS (except.... windows) but you could take a look at QuickMenu III , see some shots of it here: 486DX2 build
edit: 🤣 DK 😊
Reply 4 of 31, by DonutKing
I should update that thread one day, I've chopped and changed that system so much that it doesn't really exist any more... new motherboard and case, now its a DX4-100 with a VLB ET4000 and a YMF719, I've even upgraded the hard drive... but it still runs quikmenu 😀
In that thread I talk about using a batch file with CHOICE to launch games with seperate episodes. I've discovered a much more graceful way of doing it with Quikmenu.
In the 'Command' box for a program icon simply add a space after the filename and then [q,What would you like to choose?|option1|option2|option3]
This will bring up a dialog box with the options you specify, for the user to click on. The option will be passed to the command as an argument.
So you can have a batch file like this:
@echo off
if %1 == option1 goto game1
if %1 == option2 goto game2
if %1 == option3 goto game3
exit
:game1
cd game1
game1.exe
exit
:game2
cd game2
game2.exe
exit
:game3
cd game3
game3.exe
exit
Reply 5 of 31, by dosquest
Oh, now with quickmenu does it have a rightclick context menu approach? Or will I still have to open console and type "copy c:/dos/dos_games/lol.txt c:/dos/document"?
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 6 of 31, by dosquest
Also, to clairify I meant no suggesting "uh...windows 3.1" or something stupid like that.
Reply 7 of 31, by keropi
Quckmenu is more of a launcher gui.... don't expect it to do file management or have it's own apis...
Reply 8 of 31, by dosquest
Okay, also where am I supposed to procure a license for an almost 20 year old program that the company no longer even acknowledges it exists?!
Reply 9 of 31, by DonutKing
Quikmenu doesn't do anything if you right click. But if you click the FILES button up the top it gives you a basic mouse driven file manager. However, for DOS file management you can't go past XTree Gold (although its a textmode application and predominantly keyboard based, but very powerful).
The same place everyone else gets their 'abandonware' (not here 😉 )
Reply 12 of 31, by Jorpho
Procyon wrote:
MS-DOS 6.2 Dosshell will do the job.
MS-DOS 6.2 actually didn't include the MS-DOS 5 dosshell; it had to be added separately. (You can get it from http://support.microsoft.com/kb/135315 via olddos.exe .)
Aside from Norton Commander, Norton Desktop for DOS is pretty nice.
Wikipedia calls Norton Commander clones "orthodox file managers"; there's a list of them at http://en.wikipedia.org/wiki/Category:Orthodox_file_managers , but it doesn't say which ones are for DOS.
And there's SEAL, which hasn't been updated in a long time. The Wikipedia page links to FreeGEM and QubeOS. For that matter, there's GEOS, now Breadbox, but I'm not sure if that's free.
Reply 14 of 31, by kolano
That doesn't seem to be the case. olddos.exe provides...
-Append.exe
-Graphics.com
-Help.com
-Interlnk.exe
-Intersrv.exe
-Loadfix.com
-Memmaker.exe
-Print.exe
-Replace.exe
-Sizer.exe
-Tree.com
-Undelete.exe
...but doesn't seem to include DOS Shell.
What does have it is the MS-DOS 6.22 supplemental disk...
http://support.microsoft.com/kb/117600
Reply 15 of 31, by gerwin
Graphic Vision File Manager, looks a bit like windows but without much of an installation procedure:
http://homepage.ntlworld.com/gvision/gv/download.htm
Some Listings of GUI's / File Managers for DOS:
http://www.unet.univie.ac.at/~a0503736/php/dr … in.FileManagers
http://www.resoo.org/docs/dos/free_software/01index.htm
Reply 16 of 31, by dosquest
@gerwin I looked at the ntlworld stuff and I looked into the unet one, I might checkout the software available on resoo.
Reply 19 of 31, by gerwin
In the early 90's I used PC Shell v5.5 a lot. But it is kinda unusable since: It fails when there is a FAT32 partition present on the system.
    14.65 KiB
