First post, by Ailicec
A few months ago, I picked up a Baby Screamer on Ebay. Got it, didn't work. Recently, I swapped out the 8042 and now it boots! Unfortunately, it won't boot with the cache chips in, so I went looking for more info.
It turns out there seem to be several revisions of the board, and they differ substantially. Component placement is similar, but the jumpers and cache vary. The ones I have to look at so far include the TH99 based one you'll find on stason.org, etc, and one linked from a thread here http://mail.lipsia.de/~enigma/neu/pics/386babyscreamer.jpg.
I have looked hard for a manual, and found none. There is a Baby Screamer LC manual around; it is considerably different (seems newer - wouldn't mind having one, with the 16 meg SIMM support it goes to 128 mb). Baby Screamer LC is series 62 and seems to autodetect RAM, and has a lot less jumpers.
Mine is a "Series 42" and there's a ECN14 (engineering change notice, probably). The one I linked is an ECN05. No idea what the TH99 one is.
What I've found so far:
Static ram cache setup:
TH99 - U38 is a 24 pin DIP, U36 is a 22 pin. Tag RAM of 16kx4 goes to U36 for 64k cache, or 64kx4 goes to U38 for 256k cache.
ECN05, ECN14 - U38 and U36 are 22 pin DIPs. For a 64k cache, U32 gets a 16kx4, U38 gets a 64kx1. Tag Setup for 256k cache is unknown.
TH99, ECN05 - Appear to be same jumper setup for cache - J19,J20,J32.
ECN14 - Unknown. Logically, J37, J50, J51 would be involved. J50 and J51 are 4-position jumpers.
Other jumpers -
ECN05 and ECN14 seem to be fairly similar. TH99 has almost all of them in different positions with non-correlateable numbering. Unfortunately, TH 99 is the only one with any definitions.
I realize the chances of getting anywhere with this are pretty slim, but maybe this info will help somebody else eventually.
Practical questions out of this are: What is the cache jumper setup, and do the later revisions support 16 meg SIMMs?
I could just have a bad cache chip, but its hard to say with the jumpers being in question. Also, trying the 256k upgrade is about impossible without knowing what jumpers/tag chips are needed.
Similar about the 16 meg SIMMs - I don't have any laying around, though I'm pretty sure that SW5-8 control RAM and with experimentation might figure those out.
Thanks again. Pic the board is attached for reference.
