First post, by Mau1wurf1977
Lately I've seen a few people asking for help as to how to install a PnP Sound Blaster under DOS. So I made this little tutorial showing all the steps 😀
This video is split into three parts:
1: Explains where you can download the necessary drivers and what files you need to get.
2: Explains how to extract the drivers and run the INSTALL.EXE in order to install the drivers onto your vintage / retro PC
3: Explains if you would like to change for example the IRQ from 5 to 7 or the MIDI port from 330 to 300
http://www.youtube.com/watch?v=T9GSYgarPs4
Reply 2 of 5, by Malik
Just to help out, the required files can be downloaded from this attachment below.
It contains 2 folders : Creative PnP utilities (CTCM) and Sound Blaster 16/AWE32/AWE64 Basic Disk (SBBASIC). Both folders contain install.exe in each and will help to install the drivers in DOS.
1. Install CTCM,
then,
2. Install SBBASIC.
    SB Starter Kit.zip
    1.79 MiB
    547 downloads
Reply 3 of 5, by fronzel
ahhhh exactly what i need after installing a new board and soundcard in my SU3000. thanx a lot for this!!! I spent so much time fumbling in the BIOS for IRQ conflicts without much success. The CTCM tool looks great, gonna try this out!
