Wolfpack
First post, by Roman Bozhko
The game Wolfpack in DOSBox-0.74 is not the original sound. I remember that old computer to play a sound through the PC speaker. Distributions take different, including his own. The DOSBox-0.74 sound constant roar of engines, while, in the original sound all activities (lifting, lowering the periscope, torpedo launching, explosions...). What do we do?
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Wolfpack plays digitized sound on the PC speaker in a way that is similar to Star Control; and as with Star Control, you only hear a droning sound (it's not the "constant roar of engines") in DOSBox due to a speaker emulation issue.
You can delete the WOLFPACK.CFG file and run the game to choose a sound option other than speaker -- probably the easiest thing to do.
If it's important to you to have the speaker sound, there are unofficial builds of DOSBox that work better with Wolfpack's speaker sound. You can find ripa's speaker patch builds here; and if I'm not mistaken, ykhwong's build incorporates the patch.
