It isn't. DOSBox doesn't do cycle accurate CPU emulation so you can't emulate specific CPUs. Because of that, it's one of its strengths - speed. Your dusty old Pentium 4 2.4GHz can imitate an approximate Pentium 200 quite well in it, but you don't get a BIOS, proper ISA/PCI bus and other things a tight-as-nails accurate 'bsnes' emulator would expect.
If you really want something closer and akin to bsnes for a DOS, go follow MESS. They have bus simulation, bios emulation among other things. Just don't expect speed beyond 66mhz on a modern system and a good compatibility rate or a decent license.
You can also follow PCem which also targets specific CPUs but it's not that accurate either.
long live PCem
Debian's fucked
