silent service II
First post, by ned582
when trying to start the game I receive the following messages
runtime error R6003
integer divide Byo
run - time error R6001
nullpointer assignment
I have dosbox .73
and I have gone into the properties section of the game and click off the read only buttton
thanks
Reply 1 of 6, by leileilol
ned582 wrote:
I have dosbox .73
use 0.74
Reply 2 of 6, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Reply 3 of 6, by ned582
downloaded version .74 still had the same problem
Reply 4 of 6, by RoyBatty
You sure that's a dos game? Those error's are usually problems with floating point routines not being able to import api addresses properly in windows. This happens when some bad cracker does not unpack a file a properly and doesn't set the permission on the section back to read only. 😜
Reply 5 of 6, by wd
Rank DOSBox Author
DOSBox Author
It's definitely a dos game, most likely he failed the installation/sound configuration somehow.
Reply 6 of 6, by ned582
how do I check the installation /sound configuration?
