First post, by SquallStrife
Now that I have this 286 portable with CGA+EGA support and a 12MHz CPU, I figured it was time to make my 486 more awesome.
I procured a few parts yesterday from an awesome dude on the AtomicMPC forums, in return for making an awesome buildlog when I'm done. The haul included some dual Socket 370 boards, a dual Socket 7 board, a 486 DX4/100 Overdrive chip, a VLB ET4000, Aureal Vortex and Vortex 2 PCI, Rendition V2200 PCI, and more! I'll do photos and stuff in a separate post, I think. My camera's battery is charging as we speak!
Anywho, after years of dicking about, my 486 might finally be at a stage where I don't need to scour any more parts for it:
Gigabyte GA-486VS Motherboard
Intel 486 DX4-100 CPU
16MB FPM 72-pin RAM
Tseng Labs ET4000AX VLB Video
Winbond VLB Multi-IO
Roland MPU-IPC-T
Roland MT-32 Old
Sound Blaster Pro 2
GUS Classic 3.4
3Com 3C509B-TPO NIC
Quantum Fireball ST 4.3GB
Pioneer DVR-108 DVD-RW drive
MS-DOS 6.22
Windows 3.11
620KB conventional memory free. 😁
So, am I missing anything here?
Edit: Fixed some typos
Reply 2 of 14, by Mau1wurf1977
Just some pictures 😀
Very nice build!
My YouTube channel
Reply 3 of 14, by SquallStrife
I'd considered that. Isn't dual-booting buggy on Windows 95 versions after RTM?
Cheers Mau1wurf! 😀
Pictures coming, my camera is still charging.
Reply 5 of 14, by SquallStrife
The DVD burner is a stand-in CD drive, it's quiet, and spins up pretty quickly.
I had a more authentic Creative 8x CD-ROM drive in there originally, but it packed it in, started throwing "General read failure" errors all over the place.
Reply 6 of 14, by SquallStrife
20120212-IMG_7247.jpg by squallstrife, on Flickr
20120212-IMG_7251.jpg by squallstrife, on Flickr
20120212-IMG_7250.jpg by squallstrife, on Flickr
20120212-IMG_7244.jpg by squallstrife, on Flickr
20120212-IMG_7248.jpg by squallstrife, on Flickr
I moved the IDE cable out of the way for a better view of the CPU, that's why it's hanging off to the right not connected to anything! 😀
Reply 7 of 14, by DonutKing
Nice work!
I am running a DX4 Overdrive in my 486. I'd recommend putting a small fan on it as they do get quite hot, in my case hot enough to crash the system (leave it off for an hour or so and it would come good).
I'm curious who was the dude that gave you the stuff? 😁
Reply 11 of 14, by Mau1wurf1977
Fine looking machine with lots of goodies inside 😀
My YouTube channel
Reply 12 of 14, by SquallStrife
And just in case anybody is interested, my config.sys and autoexec.bat
CONFIG.SYS
LASTDRIVE=Z
SWITCHES=/F
DOS=HIGH,UMB
FILES=60
FCBS=1,0
STACKS=0,0
DEVICE=C:\DOS\HIMEM.SYS /NUMHANDLES=128 /TESTMEM:OFF /Q
DEVICE=C:\DOS\EMM386.EXE RAM RAM M3 A=64 H=128 D=256 AUTO NOTR
DEVICE=C:\MAX\DOSMAX.EXE N+ P- R- U02 U08 U09 U0A U0B U0C U0D U0E U70 U72 U73 U74 U76 U77
DEVICEHIGH /L:1=C:\DOS\UIDEJR.SYS /D:MSCD000
DEVICEHIGH /L:1=C:\WINDOWS\IFSHLP.SYS
SHELL=C:\MAX\SHELLMAX.COM /N+ /P- /R- /S- C:\COMMAND.COM C:\ /E:1280 /P
AUTOEXEC.BAT
@echo off
REM ===== Environment =====
SET BLASTER=A220 I5 D1 T4
SET ULTRASND=240,3,3,12,12
SET SOUND=C:\SBPRO
SET ULTRADIR=C:\ULTRASND
SET PATH=C:\ULTRASND;C:\NET;C:\;C:\DOS;C:\SBPRO;C:\DA51;C:\XTGOLD;C:\WINDOWS
SET TEMP=C:\WINDOWS\TEMP
REM ===== Sound Blaster Pro 2 =====
C:\SBPRO\SBP-SET /M:12 /VOC:12 /CD:7 /FM:12
REM ===== Gravis Ultrasound 3.4 =====
C:\ULTRASND\ULTRINIT.EXE -dj
REM ===== Other Drivers =====
LH C:\WINDOWS\MSCDEX.EXE /D:MSCD000 /L:G
LH C:\DOS\ctmouse.exe /R44
C:\MAX\ENVIMAX.COM N+
REM ===== Start Networking =====
C:\WINDOWS\NET START
menu
Reply 13 of 14, by jaqie
Get system commander. Problem solved. I've used that since the days of 95 on to multiboot systems, though it's very dated now, it's great for systems with a primary fat16 or fat32 partition.
Reply 14 of 14, by nemesis
I can second that. I've used system commander on an old Athlon system running WIN98SE, XP, DOS3.11, and Linux (don't remember which distro) partitions. I loved it and it was very stable.
EDIT: I used WIN95 not WIN98SE at first.
