First post, by depeche76
Hi everyone!I have pc p3 640 mb ram..And ı wanna instal game Z95 with dosbox version 0.65 but every instal have %44 error and give me meassage volume #0 should be insateled...pls someone possible help me?ı wanna so much play this game!thank you very muchh!!
Reply 1 of 18, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Get the newest dosbox. 0.65 is sooooo old it's not even funny anymore.
Then read the readme and the 60 seconds guide here in the guides forum. Follow that and you should be fine.
If it THEN still fails post more information, game name, where the installer is, what your mountings are
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 18, by leileilol
Dominus wrote:
game name
The Windows 95 edition of Z.
Reply 4 of 18, by depeche76
ı know game name Z The Windows 95 edition but we are told for this game shortly so..And ok I try new version now..thank you very much..
Reply 5 of 18, by depeche76
No dont intstaled dosbox 0.74..z game forum recomend only 0.62 or 0.61 or 0.65 version dosbox.🙁ı have plain one..0.74 dont open this plain..and ı use windows xp..
Reply 6 of 18, by Jorpho
Well, if the people on the "z game forum" know so much, why don't you talk to them?
depeche76 wrote:
Z The Windows 95
DOSBox will not run a Windows 95 game. Windows 95 is not DOS.
The game will apparently run in XP (without DOSBox) if it is patched.
Reply 7 of 18, by Dominus
DOSBox Moderator
If you refuse to use dosbox 0.74 ask for help in that forum. If they recommend an ancient version of dosbox it only shows their ignorance and if you want to take part in this keep it there.
Andright, dosboc cannot run Windows 95 games.
Reply 8 of 18, by depeche76
ok youre mean dosbox never cant run win.95 game?:(ok ı wanna install with 0.74 but how??
Reply 9 of 18, by depeche76
if you want ı agree your connection my pc with some program..
Reply 10 of 18, by depeche76
Are you always so disrespectful?becuase now Z forum cant working now...pls respect little for user..
Reply 11 of 18, by depeche76
Hello all
iv been playing around on my old comp here. Win 2000
was going trought some old CD-games and found KKND , Z , MDK and alot more. Realy alot of old goodies
installed. and then was reminded of the old DOS Era so long lost ^^
But i have not been using Dos-mods for years so im very rusty atm. So i was hoping you ppl could help me out a bit here
Im still getting the Main-pac error when starting Z
Version 0.72
Game is in C:Games
Also the CD is copy´d to C:/games/CD
Dos box config file
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
fullscreen=true
autolock=true
sensitivity=100
waitonerror=true
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
language=
memsize=128
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# snapdir -- Directory where screenshots get saved.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,advmame2x
frameskip=0
snapdir=snaps
scaler=normal2x
[cpu]
# cycles -- Amount of instructions dosbox tries to emulate each millsecond.
# Setting this higher than your machine can handle is bad!
cycles=11000
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# wavedir -- Directory where saved sound output goes when you use the
# sound record key-combination, check README file.
nosound=false
rate=22050
blocksize=3500
wavedir=waves
[midi]
# mpu401 -- Enable MPU-401 Emulation.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device.
mpu401=true
device=default
config=
[sblaster]
# sblaster -- Enable the soundblaster emulation.
# base,irq,dma -- The IO/IRQ/DMA address of the soundblaster.
# sbrate -- Sample rate of soundblaster emulation.
# adlib -- Enable the adlib emulation.
# adlibrate -- Sample rate of adlib emulation.
# cms -- Enable the Creative Music System/Gameblaster emulation.
# Enabling both the adlib and cms might give conflicts!
# cmsrate -- Sample rate of cms emulation.
sblaster=true
base=220
irq=7
dma=1
sbrate=22050
adlib=true
adlibrate=22050
cms=false
cmsrate=22050
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy 3-Voice emulation.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandy=true
tandyrate=22050
disney=true
[bios]
# Nothing to setup yet!
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# dpmi -- Enable builtin DPMI host support.
# This might help in getting some games to work, but might crash others.
# So be sure to try both settings.
xms=true
ems=true
dpmi=true
[modem]
# modem -- Enable virtual modem emulation.
# comport -- COM Port modem is connected to.
# listenport -- TCP Port the momdem listens on for incoming connections.
modem=true
comport=2
listenport=23
[ipx]
ipx=true
[autoexec]
# Lines in this section will be run at startup.
mount C C:\Games\z
mount D C:\Games\Z\CD -t cdrom
C:
@Echo Please Wait - Loading ......
@ZED.EXE /CD:D %1 %2 %3 %4 %5
anything im missing here ?
Thx - Hallert the Swed ^^
Reply 12 of 18, by depeche76
this is plain for dos box that forum..
Reply 13 of 18, by depeche76
and this answer who creat this plain..
UPDATED 5th July, 2006
I would like to give thanks to Devilsadvocate from Vogons forum. Most of the information came from a post that Devilsadvocate made. Also thanks to un[skill3d from the same forum for the post about the "main.pac" error. Also to The_Drummer for getting me to update this tutorial.
If you try the tutorial, please post here and let me know if it works for you. If you have problems please post here also, so that I can keep this tutorial up to date with the problems that arise.
Please read all of the tutorial below before attempting this. Try it at your own risk.
1a. Download and install the latest version of DOSBox. Recommended version of DOSBox which are most compatible for playing Z are 0.65, 0.62 and 0.61.
1b. If you get the error message "'mane.lbm' is missing, please insert CD", Download and install DOSBox 0.65 or DOSBox 0.62 instead of using DOSBox 0.63.
2. Where you installed DOSBox there is a file called "dosbox.conf" make a backup of it. [optional]
3. Open notepad and copy the following code
Code:
[sdl]
fullscreen=true
autolock=true
sensitivity=100
waitonerror=true
[dosbox]
language=
memsize=128
[render]
frameskip=0
snapdir=snaps
scaler=normal2x
[cpu]
cycles=11000
[mixer]
nosound=false
rate=22050
blocksize=3500
wavedir=waves
[midi]
mpu401=true
device=default
config=
[sblaster]
sblaster=true
base=220
irq=7
dma=1
sbrate=22050
adlib=true
adlibrate=22050
cms=false
cmsrate=22050
[speaker]
pcspeaker=true
pcrate=22050
tandy=true
tandyrate=22050
disney=true
[bios]
[dos]
xms=true
ems=true
dpmi=true
[modem]
modem=true
comport=2
listenport=23
[ipx]
ipx=true
[autoexec]
mount C C:\Games\z
mount E C:\Games\Z\CD -t cdrom
C:
4. In notepad, paste the text. Go to "Save As" and change the "Save As Type" to "All Files". Name the file "dosbox.conf" without the quote marks. Save this file to where you have installed DOSBox to and click "YES" to overwrite the original file.
5. Install Z onto your hard drive. I've installed Z to C:\Games\z
6. Copy all of the files that are on the Z CD to the hard drive in it's own folder. I've copied mine to C:\Games\Z\CD
7. Make a shortcut of the "dosbox.exe" to the destop and change the icon to the Z.ico that is where you installed the Z game. [this is optional]
8a. Start DOSBox from the shortcut on the desktop and at the prompt type Z and press enter and the game should load.
9a. If you get an error saying that the file "main.pac" is missing, open the "z.bat" file from the game folder into notepad. It should look like this.
Code:
@ZED.EXE /CD:X %1 %2 %3 %4 %5
9b. If your "z.bat" has the /yesuv like it does below, then delete the /yesuv text so that it looks like the code above.
Code:
@ZED.EXE /CD:X /yesuv %1 %2 %3 %4 %5
9c. Open the "dosbox.conf" file with notepad from where you installed Dosbox. At the bottom of the file, It should look like this.
Code:
[autoexec]
mount C C:\Games\z
mount X C:\Games\Z\CD -t cdrom
C:
10. Change the letter X in both the "z.bat" and "dosbox.config" to the letter of your CD/DVD drive. IMPORTANT. Both of the X's must be the same otherwise you will still get the "main.pac" file is missing error message. If you have more than 1 CD/DVD drive, try them all. Overwrite both files if you have changed anything.
11. If the game play is too slow or too fast, just press "CTRL F11" to slow the game down or "CTRL F12" to speed the game up. Press these until you get the speed that you like and don't press "CTRL F11" or "CTRL F12" again.
12. Quit the game. If you can't see the desktop, press the "Windows" key if you have one.
13. There should be a dos window open with "CPU:XXXXX cycles" where X is a number. Everytime you pressed the "CTRL F11" or "CTRL F12" it is displayed here. Go to the last "CPU:XXXXX cycles" that is displayed at the bottom of the list. Write down the numbers that are displayed in the last entry. Mine is "11066"
14. Open the "dosbox.conf" file with notepad.
15. Go down to where you see this.
Code:
[cpu]
cycles=11000
16. Change the numbers after the = to the same numbers that you wrote down. Mine would look like this.
Code:
[cpu]
cycles=11066
17. Save the file.
You should not have to press the "CTRL F11" or "CTRL F12" again to change the speed of the game.
18. Now start DOSBox and the game should load.
19. If you don't have sound, download this and install. http://sourceforge.net/projects/vdmsound/
Hopefully this will get the game working for you on Windows XP.
Bruce
Reply 14 of 18, by Jorpho
This is advice from five years ago! After five years of improvements, version 0.74 is unlikely to be inferior to version 0.65!
And as I already mentioned, DOSBOX WILL NOT RUN THE WINDOWS 95 VERSION OF A GAME!
Reply 16 of 18, by depeche76
Disrespectful Jorpho!jorpho are you read there?"ı would like to give thanks to Devilsadvocate from Vogons forum."there admin thank here youre told like a stupit nooo dosbox not run windows 95 versinon"!idi na huy!!!!
Reply 18 of 18, by wd
Rank DOSBox Author
DOSBox Author
Yes, topic exhausted.
