First post, by keropi
[solution in summary: use win98SE and Utlima 9 Extended Setup to tweak settings if u have additional probs]
Hiya!
after building my winME p4 machine I decided to finally play UltimaIX ... I did a full install, installed 1.18f patch and then the 1.19 unofficial one.
I made a yt vid to show you: http://youtu.be/N9Y_wn2VCFo
as you can see the framerate is really good but the character's movement is broken , the journal animation is dead slow and it makes no difference of the details setting.... it's like an internal timer or something just goes crazy 😠
I have tried the game completely unpatched, with 1.18f patch and with the 1.19 one.... all 3 behave the same.
I have tried running in Glide or D3D mode, still the same (so there is nothing wrong with the gf4 drivers I think, the v2 ones are the last stock 3dfx ones)
I even tried downclocking the cpu to 1.2ghz, still the same! 😵
the pc is running winME, a p4@2.4 with HT disabled, voodoo2 sli, gf4200ti, sblive, dx8.2 ... I am all out of ideas and found nothing on google... (I did not even find an alive Ultima series forum)
I am getting pissed at this because when I bought U9 it was running like a snail on my p3 and now that I have built a machine that has a nice framerate it just crapped out 😏
Anyone here has any suggestions? because I am all out of ideas...
edit: seems my discs are 1.18F patched from the factory, I notice the installation saying 1.18F and there is a PATCH.TXT on the cd with the... 1.18F notes... and to add more to the insult, the game runs fine on my i7/560ti/win7x64 pc, I just checked... 😳
Reply 1 of 19, by Gamecollector
Try to test with Voodoos removed. Maybe D3d mode use Voodoos, not the Gf.
Tested the game with my WinME PC (P4 3.0 GHz, X850 PE Agp). Working perfectly.
Reply 2 of 19, by keropi
the game definitely uses the gf4 because it is running at 1280X1024/32bit color... and is way smother than glide renderer... plus the same happens with glide, the problem lies elsewhere... but just to be sure I tried it with v2's disabled, still the same... also tried with EAX off, no change....
Reply 3 of 19, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
If it runs fine on the other machines it can only be a buggy driver, I think. Or a compatibility issue with the gf4.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 19, by keropi
I payed attention the the character's movement, the frames are there but are executer very slowly, like the book pages...
Dominus, the same thing happens with glide rendering , the game natively supports it and you get the 3dfx logo too... do you thing the gf4 has anything to do with glide rendering?
Reply 5 of 19, by Dominus
DOSBox Moderator
I don't know but it has something to do with your system 😉
Tinker, pull the V2 out, replace the gf4 (if you can). Try different drivers... Try the different stages of hardware acceleration in the directx control panel
Reply 6 of 19, by filipetolhuizen
The SBlive has always been a headache for me in several aspects. Try different drivers for it or replacing with a different soundcard.
Reply 7 of 19, by keropi
sblive problem? the game's sound runs perfectly...?
I will try it witn the onboard sound , just to be sure 😊
edit: completely removed sblive and drivers and using onboard ac'97 audio: still the same but with worst sound quality 🤣 and awful (software) EAX implementation
Reply 8 of 19, by filipetolhuizen
Maybe you should try updating DirectX.
Reply 9 of 19, by leileilol
Ever thought that it's because Ultima IX is just very buggy? 😀
One thing that'll help is turning off compressed textures - the GF4 can handle it, but U9's implementation in the loader seems to be broken
You might also try forcing Vsync in the video driver, perhaps U9 doesn't know what a framerate of 67fps is.
Reply 10 of 19, by keropi
using either compressed/uncompressed textures makes no difference... or 8/16bit ones... remember the same problem happens with the native glide renderer... Also tried forcing VSYNC with rivatuner, still the same...
I captured a vid with fraps, it shows better what is wrong http://www.youtube.com/watch?v=bdgAnyrsaXs
Reply 11 of 19, by filipetolhuizen
Try upgrading every driver you can (except for video ones, proven that it's not their fault). Maybe chipset drivers will do the trick. and remember to use dxwebsetup.exe to keep directx with the latest update. I remember getting some jerkiness on some setups without the chipset drivers. Try dual-booting the machine with WinXP if you can and see if the game runs with the same problem. What gives if you enable Hyper-Threading?
Reply 12 of 19, by Davros
just a wild guess try a slowdown utility
Reply 13 of 19, by keropi
I did slow down the cpu to 1.2ghz Davros... also I doubt this matters because it runs almost fine on my i7/3.4ghz pc...
The webmaster of ultimaaiera was kind enough to make a news item of my experience, maybe some dedicated Ultima fans have faced this before... check it here: http://www.ultimaaiera.com/blog/a-curious-ultima-9-issue/
Reply 15 of 19, by keropi
yes I can, tomorrow when I get back to my stash in my office... what do you recommend Dominus? A voodoo3/5, GeForce2, TNT1/2 ?
for now I am installing win98SE, just to be sure...
Reply 17 of 19, by keropi
Well... I got it running fine... 😁
The solution was to install win98SE. Same hardware, driver versions, and SP2. The game just worked almost OK, except when you opened a book the game would freeze, sound would loop and it would continue after 4-5secs (same as on my i7)
The solution to this problem was to grab Ultima 9 Extended Setup , load the “geforce user” profile and save settings. Then the book problem disappeared!
After that I am changing my views on winME, it could be my hardware combo or some random bug but I am finished messing with them for my retro needs. Back then I was using them without probs (even u9 run OK but my hardware was weak for it) but things and hardware changed now and I am not going back to a p3/500 with a s3/v2-sli setup to stay compatible with ME 🤣
It all seems fine now!
Reply 19 of 19, by filipetolhuizen
I'm glad you sorted this out. Have fun!
