First post, by Mau1wurf1977
Wondering if anyone know if such a card exists.
I'm looking for an AGP card (for my Super Socket machine), that has two VGA outputs (one can be DVI + adapter) AND output in clone mode when in MS-DOS.
This will make the recording of my videos a little bit easier 😀
Reply 1 of 11, by gulikoza
This might be interesting my Ati card (4850 hd) always starts in clone mode when turned on. On the other hand, I was very surprised when I had a nVidia GTS450 for a test and it only started on primary display. I bet AGP Ati cards do that as well.
http://www.si-gamer.net/gulikoza
Reply 2 of 11, by 5u3
What about using a VGA splitter? A decent one costs about 30€ on ebay.
Reply 4 of 11, by Harekiet
Rank DOSBox Author
DOSBox Author
I'd guess that if you extracted lot's of stuff from some linux videocard drivers and made some tool for dos based on it, you could probably do it for some cards.
Reply 5 of 11, by Mau1wurf1977
Haven't thought about that, good idea!
Thanks for all the hints guys 😀
Reply 6 of 11, by filipetolhuizen
My old Geforce 6800 cloned from the moment the computer was turned on. It was PCI-e, though, but the AGP version may work as well.
Reply 7 of 11, by Mau1wurf1977
What do I need to watch out for in regards to the AGP socket?
My MX440 does report it's an AGP8X card. I'm quite surprised as this is fairly new.
Reply 8 of 11, by jaqie
changing a light bulb by running a whole new circuit anyone? jeez...
Get a VGA distribution amplifier (talking dos, any cheap used one will do, ive got an 8x one without the box I got for free which works fine) or even if you dont mind losing a bit of the brightness/vibrance of the signal a simple vga splitter/doubler cable would work just fine.
http://www.ebay.com/sch/Computers-Networking- … d=p3286.c0.m301
http://www.ebay.com/sch/i.html?_nkw=vga+split … 6.c0.m270.l1313
or even roll your own
https://www.google.com/search?num=100&hl=en&n … cDeGhiAKp2uSUAQ
Reply 9 of 11, by Mau1wurf1977
That's exactly the issue I have with my VGA to S-Video converter. It has a VGA splitter and this really degrades the signal.
Now the Geforce I use does have direct S-Video out, but in many games it generates odd glitches. The VGA to S-Video converter avoids this.
Reply 10 of 11, by keropi
Mau1wurf1977 IMHO if you get one of those powered vga-splitters jaqie linked above you will be fine...
