First post, by dada
Hi there. I'm currently setting up a retro PC with a widescreen monitor. I'm going to run Windows 98 on it, which doesn't seem to support widescreen resolutions so easily.
So I installed PowerStrip 3.90 to try and use a custom screen mode, but it doesn't seem to like my display adapter very much:
http://wedemandhtml.com/tmp/powerstrip_error_S3_Virge.png
So it seems that this S3 Virge doesn't support custom modes. (Or perhaps that's not what that particular highlighted item means, but at least I can't seem to make any changes whatsoever. The "advanced timings" button is grayed out. I also tried PowerStrip 2.78, and it also tells me custom modes aren't supported on my hardware.)
Does anybody have a potential solution for me? I guess I could buy a new video card (actually I wouldn't mind having a bit of extra VRAM, iirc right now it's only 4MB). Anybody have a suggestion? Thanks 😀
Reply 1 of 3, by leileilol
You could experiment and modify the driver's .inf file itself to add them in. At your own risk, though.
I've done it to add 720x480.
Reply 2 of 3, by jaqie
I have a PCI radeon 7000 which has DVI and VGA and does widescreen fine, if that helps.
Reply 3 of 3, by dada
I once tried that, actually. But it's difficult to get the right modelines. I screwed up and got something like this:
http://wedemandhtml.com/tmp/IMAG0873.jpg
(also this and this happened at some point, but that's irrelevant. Just posting because they're neat pics 😀 )
Under Windows 9x, too? Also, would that be this one or this one?
