First post, by Gamecollector
- Oldbie
In WinXp Sp3 - the game installing and starting perfectly. Then, in the main menu|demo mode - it working with way too fast FPS. The two warriors for the demo are choosed - three seconds w/o demo or with 1 frame - another two are choosed. Plus the music/sound is also too fast.
"Vertical sync always on" in the driver settings - no reaction.
Tested with P4 3.0E/ 2 Gb RAM/ X850 PE Agp/ Catalyst 10.2/ WinXp Sp3.
P.S. In the WinME - the game is working with desired FPS.
Can someone tell me the way to properly run this game with WinXp?
Tnx.
