Favorite font in DOSBOX
First post, by dejanr
Is it possible to use my own favorite font in the DOSBOX window? The font is attached - it is a console font, works well in the DOS window of 32-bit Windows.
I tried to load the font from within DOSBOX, but did not know how. In Windows I just select Properties / Font and select Raster Fonts, and then 11x20 font and it just appears.
Please help.
Reply 2 of 4, by IIGS_User
Don't mix DOS box with DOSBox.
Klimawandel.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
you can do it the same way as you did in the DOS days. (it's a table in the emulated memory, easy to change with an utility or TSR)
However you can't do weird resolutions as 11x12
Water flows down the stream
Reply 4 of 4, by Joey_sw
some early VGA (256KB version) did support weird font height between 8 to 16 for their non-standard text modes.
you still need 1 bytes (8 pixels) per 'line', so 8x## fonts
-fffuuu
