noshutdown wrote:there are p3-1133ghz(133*8.5) in existance, fastest coppermine p3.
using 1100 on bx is a reasonable idea, i am also after that.
You don't want the early 1133mhz version, though. It is unstable as hell and doesn't perform well even at the settings it is meant to be run at. It was rushed out too soon so Intel could say they had something that could top the fastest Athlon. There is a later version with the bugs corrected and the performance back up to where you would expect it to be, but you have to know which one you're getting before you buy.
SL4HH is the one you want to avoid. Most were recalled but a few may have slipped the recall and still be out there, so be careful.
