jaqie wrote:total memory.... 16,239,616
16MiB=16,777,216 (16*1024*1024)
640KiB=655,360
🤣 I never looked on the 655.360 value... so it does take some mem... I always thought it updated the bios shadow area or something like that...
The 16MB value is OK though as the IBM machine allows a total of 15.872kb available to the end user. The rest are reserved from system boot. (the memory count+test is up to 15.872kb - and it happens every cold boot and you cannot bypass it and there is no way to reclaim them 😵 )
@DK: meh, I'll still gonna use 9.57 as I prefer it to allocate mem beyond the user's 640kb even if it means you get less than 640kb... that way it's more difficult for a prog to try reclaim or tamper with it since it's located outside the user area, both convecntional and HMA as it seems... also with almost 620.000 free bytes of conventional ram I don't see a reason to try and reclaim the lost mem 😊
