First post, by trist007
trist007
Offline
The sound works great, but the music, for some reason, does not play.
I have a Soundblaster AWE64 GOLD with 20MB. The computer is a Pentium 2 333Mhz with 64MB of RAM. I have windows 98SE so I think I'm running DOS 6.22. I setup the FM and the sample to Sound Blaster in the D:\install.exe script. When I run the soundblaster utility diagnose, I can hear music and sound working fine. Here's my config.sys and autoexec.bat
CONFIG.SYS
DEVICE=HIMEM.SYSrem DEVICE=EMM386.EXE RAM FRAME=E000 I=B000-B7FF D=48DEVICE=EMM386.EXE RAM D=48rem DEVICE=EMM386.EXE RAMDOS=HIGH,UMBDEVICE=C:\SB16\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5DEVICE=C:\SB16\CTMMSYS.SYSDEVICEHIGH=C:\ATAPICD.SYS /D:MSCD000LASTDRIVE=Z
AUTOEXEC.BAT
@ECHO OFFSET TMP=C:\SET TEMP=C:\SET PROMPT=$p$gSET winbootdir=C:\WINDOWSSET PATH=C:\WINDOWS;C:\WINDOWS\COMMAND;C:\SB16SET BLASTER=A220 I5 D1 H5 P330 E620 T6SET SOUND=C:\PROGRA~1\CREATIVE\CTSNDSET MIDI=SYNTH:1 MAP:E MODE:0LOADHIGH SMARTDRVLOADHIGH CTCMLOADHIGH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:MSCD000rem LOADHIGH C:\UHCI.EXELOADHIGH C:\MOUSE\MOUSE
[/code]
