First post, by keropi
- l33t++
Hiya!
today I installed win3.11 on my p200mmx dos machine... everything runs OK but I don't really get the MIDI MAPPER stuff... let me explain with nice pictures 😁
a: this is the midi mapper without the SB16 installed, it has some default devices and I just added LAPC-I (driver in devices) :
and here is the LAPC-I's settings:
nice stuff and the sample windows midis sound fine 😊
b: then I add the latest SB16 driver and I have these devices:
seems fine, sfx work fine , FM works and the DB50-XG works too... but the LAPC-I setup in MIDI Mapper is deleted. The SB16 driver just replaces midimap.cfg with it's own and does not care about any other devices.
So I just add manually a LAPC-I setup:
that looks like this after I edited the channels:
there are no patch map names to choose from so all channels are "none" and not mt32 ones... So I just made it to look like the original LAPC-I midimap.cfg ... is this correct? LAPC-I does work for midi but since the SB16 setup also deletes patch maps it sounds VERY wrong... 😖
So what I am doing wrong? what do I miss? 🙁
I would really welcome some feedback on this 😢
Thanks in advance for any info/help!
