First post, by lucky7456969
dc21x4 driver. Disable DHCP. Where can I set something similar to my_ip=x.x.x.x using Virtual PC 2007.
Thanks
Jack
Reply 1 of 4, by Jorpho
It is probably an option that can be set in whatever driver you are trying to use.
A Google search for <"virtual pc" "dc21x4" ip dos> suggests that it is in protocol.ini. (Yes, that's probably a Windows thing usually, but apparently it works for DOS too.)
http://www.winvistatips.com/dos-networking-vpc-t521121.html
Reply 2 of 4, by jaqie
.ini is just a text data file with CR separated values, has nothing to do with being a 'windows thing' or any OS, except for the fact that linux text files are CR+LF (or vice versa, never can remember which is which).
Reply 3 of 4, by SquallStrife
It's a bit more than "[newline] separated values", it's a primitive database of key+key+value sets.
[section]
key=value
;comment
Reply 4 of 4, by DonutKing
I think Jorpho was referring to protocol.ini itself being more likely to be found in Windows, rather than in DOS.
The MS TCP/IP network drivers for DOS do have a protocol.ini
So if that's what the OP is using that's where he needs to look.
