First post, by ncmark
I have a very, very strange shutdown problem with win98.
The board is a tyan trinity 1854. I recently changed out the CPU cooler with a slightly bigger/quiteter one. For those of you familiar with the board, it has both slot1 and socket 370. I removed the plastic mounts/guides for the slot 1 to make room for the slightly larger cooler (don't think that is the problem).
But now, win98 does not shut down proeprly. When I shut down, it powers back the fans and the hard drive light starts flashing, but it does not shut off.
As strange as it may sound, I have traced this to the case fan. If I unplug the case fan, it shuts down properly. I have even tried a different case fan, same result.
I could probably get by without the case fan, or even hard-wire it to an unused drive cable, but why is it doing this? I am starting to think something on the motherboard is damaged 🙁
Reply 1 of 4, by Procyon
Hi, I am totally unfamiliar with your board, but have you tried upgrading the bios, if you haven't got the latest one that is.
Also if I remember correctly, Windows 95 and 98 didn't shut down by themselves, when you terminated windows you got a screen saying you can turn off the computer.
Reply 3 of 4, by AdamP
It's possible it's a PSU issue. Some fans use more power than others. Do you have a multimeter to test it with?
Windows 9x does shut down automatically if you have an ATX motherboard.
Reply 4 of 4, by eL_PuSHeR
[Thread moved to PC Section]
