First post, by Hudson187
Gents,
I recently acquired a older tower from a tag sale that housed a Biostar M5ATA mobo with a P200 and 24meg of EDO ram. I've been tinkering with it for the past month or so, putting Windows 95 on it along with a PCI 8mb Rage XL card, Diamond Monster 3D (V1), a ISA ESS 1868 SC and a 10/100 PCI NIC. Everything was working fine until last night; I installed a new CD-ROM unit (was fine, found within bios and Win95) and updated the Rage XL drivers. I also put in a P233 (changed jumpers appropriately per the manual -- processor was found by bios and I was able to boot into Windows, even played a few games). Everything was fine for about an hour. This is when things when bad -- I decided to reset the bios to default to see if it helped my performance; Skynet @ 640x480 wasn't working as well as it should have. After resetting the bios, the unit began to boot into Windows, then it just stopped with only the underscore blinking in the top left of the monitor. I let it sit for about 5 minutes and nothing, so I hit the reset button. Now, I get a bios beep from the onboard speaker and another beep from the offboard speaker. The beeps go as such:
Onboard: 1 long beep (about 1 1/2 sec), then 3 short beeps.
Right after the onboard error beeps, the offboard speaker goes:
1 higher pitched beep, about 1 1/2 sec, then a lower pitched beep for the same duration
I've pulled out all PCI/ISA cards, unplugged all IDE/Floppy connectors, reseated the P233 CPU, put the P200 back in, removed all 4 sticks of ram (gave a different code then), tried with 1 stick (each of the 4 at different times), etc, etc.
Any suggestions? I thinking its either a no video card error and my Rage XL is toast, bios is corrupt, all memory is bad, both CPU's are bad or the mobo is bad. I looked up Phoenix error codes but nothing matched.
Thanks!
Reply 1 of 14, by shspvr
The bios are Award
1long, 3short = No video card or bad video RAM, Reseat or replace the video card.
Reply 2 of 14, by Hudson187
Excellent -- where did you find that by chance?
I will try another video card tonight -- I'm hoping this works!
Thanks!!
Reply 4 of 14, by Hudson187
I just tried another PCI video card and same thing.
Its actually just one long beep, then two beeps, however that site says its a Video Adapter Error.
Any suggestions?
http://www.hudson187.com
Reply 5 of 14, by shspvr
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered.
What Vidoe card is it
Reply 6 of 14, by Hudson187
I tried two completely different ATI Rage XL 8mb PCI cards.
Reply 7 of 14, by Hudson187
I just tried a old PCI Cirrus based card and same thing. I'm thinking the bios are corrupt... any ideas of where I can find a copy of the bios? I searched up and down on Google and could not find anything!
Reply 8 of 14, by Hudson187
I called Biostar -- they do not have the bios anymore 🙁
Reply 9 of 14, by Hudson187
Found this on Biostar's site:
What is the motherboard's error beep code mean?
The only AwardBIOS beep code indicates that a video error has occurred and the BIOS cannot initialize the video screen to display any additional information. This beep code consists of a single long beep followed by two short beeps. Any other beeps are probably a RAM (Random Access Memory) problems.
New RAM came in today and I tried that... same thing. I was able to find a hacked copy of the bios for large disk support. I suppose the next step is to try and flash the chip to that using a USB EEPROM flasher I have @ work.
Reply 10 of 14, by luckybob
this is another case where having a pc analyzer would probably shed more light than anything else. You can get them off ebay for a SONG: http://www.ebay.com/itm/390086356681 There is no excuse to not have one in this line of work.
From what you said, I would not be surprised if the power supply is failing. Do you have a multi-meter (another item everyone should own)? If any of the voltages are off by more than 10% something is horribly wrong.
Reply 11 of 14, by Chewhacca
I've had these problems with ati ragexl cards and old motherboards in the past. I've found in general that they simply don't work at all.
Reply 12 of 14, by Hudson187
"I've had these problems with ati ragexl cards and old motherboards in the past. I've found in general that they simply don't work at all."
A RageXL was working fine until this problem arose. I also tried a Cirrus based card with the same issue.
I'm going to pick up one of those Analyzers. I was thinking the PSU was causing issues too, however I'm having difficulty finding a inexpensive AT PSU to swap. I am going to pick up another CPU just to make sure that both of mine aren't fried.
Reply 13 of 14, by shspvr
My beat on the motherboard.
Reply 14 of 14, by Hudson187
Another CPU should be here today -- I'm hoping its not the board!
