First post, by SamTinribs
I'm new to Dos Box and i would appreciate some help setting up Fable for my computer through the Dos Box, Can anyone help, maybe give me some instructions? Many Thanks
That's a Windows game, not DOS.
Your frist instructions besure that read the minimum system requirements here http://support.microsoft.com/kb/905588
Sorry This is the one i have, i thought it was called the lost chapters from what some friend thought i was on about. Is there any help you could give me for installing 'Fable' (Not 'Fable: The lost chapters) I have the CD-ROM, i install it onto my PC as 'C:\FABLE\' And i have installed Dos Box version 0.74 for my windows PC. What shall i do now?
If you're new to Dosbox, it's quite a long way to go about it. You have to go through the readme file which comes with Dosbox.
I suggest you download D-Fend Reloaded (http://dfendreloaded.sourceforge.net/) which will make it easier to "mount" the cd-drive and setup and so on.
If that's complicated, try reading through the dosbox readme again. All the basics are explained there.
Read and follow the 60 seconds guide - see my sig
[Thread moved to DOSBox General Section]
Thanks for the support
