First post, by Artex
- l33t
I picked up an Orchid Righteous 3d (3DFX Voodoo) off ebay, but it didn't include the passthrough cable. Anyone know where I can get one?
I assume that's not your photo then, as there is a passthrough cable there 😀
You can use any VGA extension lead. You can find 6" and 12" leads if you look around. You can also get VGA gender-benders for a couple of bucks if necessary.
Yeah, not my pic. 😀
So it's just a VGA cable? Nothing special?? Can you throw up a link to one?
Yeah just a standard VGA lead, the pinouts are the same, the only thing to watch out for is the male/female connectors, which is what the gender benders are for.
Its been a couple of years now but I setup a Voodoo 2 box and just bought a standard 12" VGA extension cable with a gender bender and it worked perfectly. I just got it from a local shop, but any standard VGA lead should work.
VGA port saver cable looks ideal for this
http://www.ebay.com/itm/StarTech-com-6in-Coax … =item2c6447fe14
If your monitor has 2 inputs and your other gfx card has dvi I think you can connect both cards to the monitor and they will work without a passthrough
Nice!!
