First post, by eddy2by4
So I'm runing Windows 7 x64 and after I've installed dosbox, it seems that by default its set to widescreen. I am runing on an 4:3 monitor set to 1280x1024
I've tried to tweak the settings, and finally got something when i set
fullscreen=true
fulldouble=false
fullresolution=800x600
windowresolution=original
aspect=true
But, when I fullscreen its not maxed out, some dark parts in the margins and in the center I've got the dos box.. I tried changing the resolution to 640x480, but then again.. it appears wided out like its set to widescreen.
Please give me the proper settings, so I can see full screen maxed out dosbox, on my 4:3 monitor runing 1280x1024 resolution all the dos screen.
I dont play any games, I need this for Borland C.
Thanks.
Reply 1 of 1, by Mau1wurf1977
[sdl] fullscreen=true fullresolution=0x0 output=opengl […]
[sdl]
fullscreen=true
fullresolution=0x0
output=opengl
[render]
aspect=true
scaler=normal3x
This should give you a perfect picture for games. No idea about Borland C / text modes...
