Scale dosbox application
General information and assistance with DOSBox.
Postby tsaenger81 » 2012-4-17 @ 14:30
Hello,
i am trieing to use dosbox for an old DOS-Application.
At the moment it looks like it will work fine.
Now i try to optimate this Application usage.
I am wondering if it is poosible to scale the application. There for i used the command
Code: Select all
scaler=normal3x
but nothing happens.
I also changed the output to overaly
I am using dosbox with Win7 64 Client system.
Thanks for help
Tobias
tsaenger81
Re: Scale dosbox application
Postby Qbix » 2012-4-17 @ 14:34
add forced
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby tsaenger81 » 2012-4-17 @ 14:39
you mean:
scaler=normal3x forced ?
I tried it, but nothing happends
tsaenger81
Postby tsaenger81 » 2012-4-17 @ 14:59
i think it wont work because i am using the dosbox_geruml_locking patch.
My problem is, that without this patch my application won't start.
Or is there an possibility to use the actually dosbox with file locking?
Thanks a lot
Tobias
tsaenger81
Postby VileRancour » 2012-4-18 @ 11:45
I don't see why a patch for umlauts and file-locking should interfere with the scaler. Try to specify a target resolution ("fullresolution" and "windowresolution" config settings).
User avatar
VileRancour
Return to DOSBox General
Who is online
Users browsing this forum: Baidu [Spider], Bing [Bot] and 2 guests
