First post, by TheLazy1
TheLazy1
Offline
I've got a Creative DXR2 card here which if I'm correct, is basically useless and no one wants them.
However, there is memory soldered to it which could possibly be compatible with my S3 Trio64 video card.
Memory on card: NN514265AJ-50 Dynamic RAM, EDO, 256K x 16, 40 Pin, Plastic, SOJ
I'm pretty sure it would fit the socket, but the memory already on the S3 card is 60ns.
Is this a worthwhile tree to be barking up?
[Edit]
The answer is they're stuck to the PCB and the heat gun won't take them off.
Giving up.
