EF2000 & CH Fighterstick in DOS BOX
General information and assistance with DOSBox.
Postby XOPEK » 2012-4-22 @ 19:25
Hi everyone! I have some kind of problem with DOSBOX +EF2000+CH Fighterstick .
It begins from config: when i try to calibrate X&Y axis the arrow in the calibration screen looks to the left lower corner even after i moved it through the circle.The thrust axis also shaking & calibration arow do not moves at all when try to move it from min to max position. After start of the flight- the plane begin to spin around his axis & thrust do not work.
By the way in windows (using CH Control Manager ),all is ok(i mean -it calibrates fine,all buttons work properly). Do anybody have(had) such trouble?Is it some solution exists for that trouble ? Thanks for your answers!
p/s My system specs:Core2Duo E8500,260GTX,4Gb RAM,Windows Xp & 7
XOPEK
Re: EF2000 & CH Fighterstick in DOS BOX
Postby bored » 2012-4-22 @ 20:16
I had similar behaviour with a Logitech stick. A change to the dosbox conf file fixed things. Here's my joystick section:
joysticktype=auto
timed=false
autofire=false
swap34=true
buttonwrap=true
bored
Postby XOPEK » 2012-4-23 @ 02:34
Thanks for your reply! But when i make such changes as you wrote- config file do not see any joystick :( Or i need to use keymapper of DOSBOX before starting program?
XOPEK
Postby XOPEK » 2012-4-23 @ 19:52
Yes-thats correctly! It works fine after mapping AXIS in DOS BOX Keymapper before starting config file of the game.Thank you very much!This problem is solved
XOPEK
Return to DOSBox General
Who is online
Users browsing this forum: istellabot [Bot] and 1 guest
