First post, by oleha
Hi,
At work we have one computer left that has MS-DOS. This computer also consists vital code which are ran on bootable MS-DOS floppies.
As a developer I'm very afraid that the hard-drive on the developer station will break, which would give a lot of headache. Well, my first weapon against this is to try to make a virtual ms-dos computer, before I port my code to Win-64.
So therefore I've been recently installing MS-DOS 6.22 on DosBox following the instructions at
Installing MS-DOS on DosBox.
Further on I need to install Borland C++ 3.1 and PCTCP-kernel.
How do I do it? I've downloaded the compiler, but how to I create a image from it, so I can mount it as a CD-ROM or a harddrive image?
I also have code that I need to modify and share with Win7 (subversion), how can this be done? Applications we have written can be booted in bochs with internet support using pctcp-kernel.
Thank you very much for your replies,
Ole J.
Reply 1 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Mount the folder which contains the installers as c in dosbox, imgmount the dos 6.22 image as d, use the copy command to copy the installers from c to d.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 4, by eL_PuSHeR
[Thread moved to DOSBox General Section]
Reply 3 of 4, by Davros
oleha wrote:
As a developer
If your the developer you should really be recompiling your code to run on modern systems.
http://edn.embarcadero.com/article/20633
Reply 4 of 4, by Jorpho
Are you sure you need to boot MS-DOS 6.22? Is your code doing something complex (like lower-level disk access) that can't be done normally in DOSBox?
