DOSBox mount under Flypad / Android
General information and assistance with DOSBox.
Postby fred112 » 2012-4-29 @ 19:32
Hello,
I have a DOS game that I want to play with Dosbox for Flypad (Android).
My problem is that I need to install the game.
It went under Dosbox for WIndows:
mount c c: \ tri
imgmount e c: \ triu \ game.cue -t img
Under Dosbox for Android, I'm not tuned to the directories!
I hope someone can help me?
greeting,
fred
fred112
Re: Doxbox mount under Flypad / Android
Postby Xelasarg » 2012-4-30 @ 09:53
Depends on your OS.
Android 2.x.x: "mount c /sdcard/DOSGames" (or "mount c /sdcard/external_sd/DOSGames" if you store your games on an external SD-card)
Not quite sure about Android 3 and 4; I know that ICS mounts the sd-card differently, but I didn't like ICS, so I went back to Gingerbread again after a few days. Something like "mount c /emmc/DOSGames" should do the trick.
Just download a free file manager like ES File explorer to see the mountings.
And I'd suggest you install the game through windows and copy all the stuff to your tablet afterwards. Just make sure you mount the same DOS directory (e.g. "mount c c:\tri" in Windows and "mount c /sdcard/tri" on your tablet).
"What's a paladin?!"
User avatar
Xelasarg
Postby fred112 » 2012-4-30 @ 14:24
Hello,
there is, is already mounted / sdcard / with c
When I start andosbox, then sthet first mount c / sdcard /
and has been changed to c
Can I reset that?
greets,
fred
fred112
Postby Xelasarg » 2012-5-01 @ 05:43
I'm not quite sure what you want to do, but I'd suggest you have a look at the file andosbox.conf in the root directory of your sdcard. Use any file explorer to get there.
User avatar
Xelasarg
Postby fred112 » 2012-5-01 @ 11:47
Hello,
I find the directory where the point was installed!
Do I have to adjust because what, so I can see the directories?
I want so there adjust it so that nothing is beformounted.
greeting,
fred
fred112
Re: DOSBox mount under Flypad / Android
Postby Qbix » 2012-5-01 @ 19:35
Ask where you got the port.
We don't support it.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Return to DOSBox General
Who is online
