First post, by dosfreak70
Hello,
I need some help in connecting my PC via the printer interface (parallel) with another communication terminal.
The old DOS soiftware should enable me to read and write the memories / registers of this terminal. The old software - ComDat - runs perfectly and it connects via LPT1 to the teminals printer interface (with a Laplink cable).
However the command "download register" responds wit a black DOS window and the Message: "Achtung! Interner Programmfehler bei der Speicherallokation über den Heap" which means: Attention! Internal program error in memory allocation on the heap. (see attachment)
Does anyone has an idea what to do or amend in the DOSBox configuration file?
Reply 1 of 2, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
You know DOSBox's main target are games not applications. Don't you?
Your mileage may vary.
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
it makes no sense that you end up at z:\
you have to change to the C drive and go to the directory to run it.
So DON'T DO THIS
c:\app\app.exe
but something like this
c:
cd app
app.exe
And of course dosbox is intended for games not apps.
edit: printer port ? We don't emulate that, so you are out of luck
Water flows down the stream
