First post, by lucky7456969
- Oldbie
Try 1.1, it's no good, but there is a vhd of this version floating around on the net.
Don't know what it is good for?
Thanks
Jack
Thanks
Jack
none of them
Is it possible to run os/2 on the pc anyways?
Thanks
Jack
If there is a vhd then it is likely to run in ... Go google what program introduced vhd...
Seriously what even lead you to believe any flavour of OS/2 will run in Dosbox?
Thanks, then I will change to vpc and see how it goes
that file actually works, but i am not sure how to change its "wallpaper", dump a picture for you to view later
That works and boots but the desktop is in complete chaos, seems to be virused.
I want to install vm additions, but i even don't know how to run a program in os/2
there is a undo and default options at the bottom of the window, but there is no "run" button
Please help
Desktop in chaos MUST be a virus. suuuuuuuuure
I bet you can run programs by double clicking the binary. Usually works in most OS'.
