First post, by kool kitty89
Can normal P55C processors be used with the AdvancedML board? It's an HX board, but seems to lack split-rail voltage. In fact, I can't seem to find any mention of adjustable I/O voltage support either (just 3.3V, no 3.52, etc) given the technical info here: http://www.bcmcom.com/tech/sq598/28180602.pdf
However, it does seem to functionally work with MMX chips, just at the expense of overvolting them (or using the 3.3V specced POD W/MMX) and I even see some mentions of Marl systems using 233 MHz parts, like this: http://alasir.com/software/ramspeed/logfiles/p55c-430hx.html
OTOH, I also found this old thread warning against using MMX parts with the board:
http://groups.google.com/group/intel.motherbo … a814bab29c9a35a
The Intel(R) Advanced/ML motherboard commonly referred to as the Marl does not support the Pentium(R) processor with MMX(TM) tec […]
support the Pentium(R) processor with MMX(TM) technology. It does not have
support for the split plane voltage. The core of the MMX(TM) processor is 2.8
volts unlike the normal Pentium(R) processor, which is around the 3.3 volt
range. It is possible to cause damage to the processor and or the motherboard.
The upgrade path for this motheboard would be the 200-MHz Pentium(R)
OverDrive(R) processor with MMX(TM) technology, the part number for this
processor is BPODPMT66X200. You also may want to check the motherboard for the
AA and or PBA number on a sticker on the motherboard itself to ensure that this
is the Intel version of the Marl motherboard and re post with those numbers so
we can check for you.
But, to be honest, this sounds more like a straight quote from intel literature rather than practical advice on the subject. Ie, not officially sanctioning running parts out of spec, as most firms will do for liability reasons (same for overclocks, etc).
From what I gather, the Pentium MMX Overdrive is really the same 350 nm chip as the stock P55C, just with additional testing to clear it for official 3.3V operation and a different thermal envelope and many normal MMX parts wil work perfectly fine at 3.3V (not to mention overclockers boosting voltage for other reasons). Granted, the chips will certainly run hotter (just like the MMX OD), but still not very warm even by standards of the time.
3.3V isn't really pushing it for normal 350 nm chips in general either, the late model P54Cs were 350 nm too, plus the Winchips all specced at 3.52V, and of course the K6-233 specced for 3.1~3.3V.
Other than that, the Advanced/ML seems like a great platform for the P55C with the high-end 430HX, albeit with the 128 MB RAM limit, and still better than VX or TX boards there since it can cache all 128 MB.
Edit: I see I was wrong about the POD-MMX, it does actually use an onboard voltage regulator rather than running natively at 3.3V, though this does still seem a bit excessive for that type of chip. (certainly not like the case of running 3.3V 486 parts in 5V boards)
Reply 1 of 7, by kool kitty89
Aside from this specific motherboard case, does anyone here have experience or tips with running Pentium MMX chips at 3.3V?
Aside from running hotter, I'd think they'd tolerate the overvoltage reasonably well given the 350 nm process used and that the 350 nm Pentium Classic, Winchip, and K6-233 all ran at 3.3 and/or 3.52 volts.
Reply 2 of 7, by Old Thrashbarg
They'll work on 3.3V, and the maximum spec voltage is actually 3.7V (though that's the stress rating rather than the functional rating). But you'll definitely want some decent cooling on it, and even so I don't know what the long-term reliability is like. Pentium MMX chips are cheap and plentiful, though, so it's not a huge loss if you fry it.
There are a couple other options too, if you want to play it safe... Intel made PMMX Overdrive versions, which were specifically intended for use at 3.3V. Also, a few companies made voltage converter/adapters that were basically voltage regulators that went in between the CPU and socket. Either one can be found relatively frequently on eBay, for fairly reasonable prices.
Reply 3 of 7, by kool kitty89
I picked up a couple MMX 200s and a 233 for about $3 each, so I wouldn't really mind risking it.
The main concern (for bot me and the friend in question) is whether there's any risk to damaging the board, namely whether the voltage regulator can handle the added power consumption.
However, since several of the socket 5 native 6x86 chips should be similarly hot/power hungry (if not more so), then that shouldn't be an issue either. Albeit, it is an intel-specific OEM board and such parts many not be taken into account. Given the apparent fixed 3.3V setting, it would also bar the many 6x86/K5/Winchip parts requiring 3.52V.
Plus, unless those adapters and PODs are using nonlinear regulators onboard, the power consumption should be very similar to running a P55C natively at 3.3V. (a linear regulator would simply be cutting that 3.3V down to 2.8 and dissipating the heat -vs nonlinear converting voltage and amperage)
The board seems to be cleared for the POD MMX 200, so running a plain MMX 200 at 3.3V would probably be the safer limit rather than attempting a 233. Though that old benchmark archive mentioned in the opening post specifically mentions using a 233.
As for cooling, the current system is already set up with a decent heatshink and fan with thermal paste applied. The heatsink is on the small side, but not much different from what's common on PGA Mendocino Celerons and a fair bit heaftier than the stock Intel heatsinks for Pentium MMX.
That set-up is probably overkill for the Pentium 133 currently in the system. It seems it was pretty common to not even bother with thermal pate for those CPUs, or even no fan if the heatsink was a decent size and a case fan present.
Reply 4 of 7, by Old Thrashbarg
Well, you'll really need to look at the board's voltage regulator chip to be sure on that. Just find the number on it and do a search for the datasheet... that should tell you the rated amperage on it. If it's good for 7A or more, you should be fine, 6A would probably do it but you'd want to keep a close eye on it to make sure it's not getting too hot. I wouldn't try it on a <6A regulator.
And you really can't judge based on the power consumption of 6x86 chips and the like. Remember, this is an old Intel board you have... it shouldn't be much of a surprise that Intel boards have rather poor support of third-party processors.
Reply 5 of 7, by kool kitty89
In that line of thought, it would be good to make sure the regulator also has a decent heat spreader on it and not a barely-adequate tiny cheap one that some tend to use.
Right, I mused on that possibility above too, and the fixed 3.3V setting is pretty indicative of that too.
Reply 6 of 7, by ApolloBoy
I'm the friend kool_kitty mentioned, and there's no problems to report so far. It seems to run pretty cool even though it's not running off split-rail voltage and I managed to get a nice little speed boost out of my DOS/Win 95 rig.
Win98 Rig: Pentium 200 MMX, STB Velocity 128, SB 16, 64 MB RAM
286 Rig: Harris 286-20, ATI Ultra, SB Pro 2, 1 MB RAM
Linux Media Center: Athlon 64 X2, 4 GB RAM
Reply 7 of 7, by kool kitty89
Oh, cool, you can log-in again. 😁
For those interested, here's the original thread for Apolloboy's Pentium build:
My Pentium 133 build
As you can see in his sig, he's since upgraded to 128 MB EDO DRAM, Win95, and a Velocity 128 (Riva), and of course the MMX 200.
He's also running it through an external video scaler/converter box to a PVM monitor through S-video (cleaner and less buggy than the Riva's onboard TV-out, or the ISA TV-out card he was using before -which was also DOS-specific iirc). So practically limited to ~640x480i max resolution. (and 60 Hz interlaced refresh) Still, not bad for what the sort of games the is being used for, and certainly not bad considering console gaming standards of the same period.
