Graphics card?
First post, by someperson42
I've been thinking about replacing the 2D card in my 98SE/DOS rig. I'm currently using a Tseng ET6000, but I come across games from time to time that just don't work properly, such as Commander Keen 1, which has jerky motion. Can anyone suggest a good replacement, or do pretty much all cards from this era have their own quirky issues?
My rig:
233 MHz Pentium MMX (actually an overclocked 200 MHz -- seems stable)
256 MB RAM
Tseng ET6000
3dfx Voodoo 2
Aztech Sound Galaxy Washington 16
NEC XR385 daughterboard
Reply 1 of 20, by keropi
I have 2 similar systems with a pentium mmx and once I installed riva128(zx) cards I never looked back.
Keen games are fine, scrolling is awesome.
Fast and VBE3.0 out of the box 😀
Reply 2 of 20, by dirkmirk
If you dont care about 3d acceleration a s3 virge DX would be fine.
Reply 3 of 20, by laxdragon
I was a big fan of the Matrox Millennium back in the early 90's. It was an awesome 2D card that never gave me any issues.
My preferred combo in the early Win98 days was a Millennium for 2D, and a Dual VooDoo 2s in SLI for 3D.
laxDRAGON.com | My Game Collection | My Computers | YouTube
Reply 4 of 20, by vetz
I'll sign under on that 😉
Reply 5 of 20, by sliderider
A Matrox Mystique or Millenium G100/G200 would probably handle most everything the rest of the parts in that system can without breaking the bank. I wouldn't waste a lot of money putting anything too powerful in such an old system because it would be wasted without a stronger CPU to back it up.
Reply 6 of 20, by noshutdown
try a rendition v1000
Reply 7 of 20, by bushwack
Don't forget about the ATI 3D Rage Pro, I figure it's on par with the Riva 128.
Oh and those Pentium MMX's are all good overclockers. My 200 easily does 266 (75x3.5) and with a good motherboard, memory and cooling you can push them to 290 (83x3.5).
Reply 8 of 20, by luckybob
If you have a voodoo 2, then a nice matrox card will do you right. Matrox and voodoo seem to go together like apple pie and ice cream.
I have several cards. I'll send you a few in trade for your et6000.... ^.^ shoot me a pm if your interested.
Reply 9 of 20, by badmojo
A Matrox card is great for most things but not Keen:
Best DOS video card?
I was using an ET6100 up until recently in my socket 7 machine but found that it was causing corruption in Dune2.
Reply 10 of 20, by keropi
^ riva128 based cards work fine with those 2 games... 🤣 🤣 🤣
Reply 11 of 20, by bushwack
Yeah when I first built my P200 I used a Matrox (Millennium or Mystique cant remember) after reading all the praise for so long. I didn't care for it, the Win95 driver was flaky and DOS, sometimes it did some weird stuff. The Virge isn't perfect either, but I've had better luck with it, for the games I play anyway. Maybe Matrox is aimed more at productivity. 😦
Reply 12 of 20, by keropi
AFAIK Matrox almost always aimed at productivity.... IMHO they only "experimented" with the Mystique
Reply 13 of 20, by someperson42
Sounds great, except all the Riva 128s currently on eBay are AGP, which my board does not have. Did they ever make a PCI version? If not, then this isn't an option for me.
If it's anything like the on-board ATI 3D Rage II+DVD in my box, then all I can say is "no". It has compatibility issues (most notably with *all* Keen games), and it has a strange problem with thin lines quickly appearing across the screen, which is especially bad when displaying a per-pixel checkerboard pattern.
This thread is why I'm reluctant to go with a Matrox. I'm a big Keen fan and I'd hate to not be able to play it on my main retro machine, not to mention that it probably means that there are other compatibility issues.
This is currently what I'm leaning towards getting. The S3 Virge seems to be plentiful and cheap online, and I've read some good things about it. Any thoughts?
Reply 14 of 20, by Markk
I'm not sure if I've mentioned that before, but I think I found a "fix" for the keen games. Right now I'm using a Celeron 500 with a Matrox G200 card. Normally it won't play the commander keen games ok, but if I disable the L1 cache, all problems are gone and it plays great. But I haven't tested that with other Matrox cards so as to be sure that this applies to all of them.
Reply 15 of 20, by keropi
S3 are surely a great cards and won't trouble you much! I can highly recommend the Virge/DX line, and personally it's what I used before I find out that riva cards are faster and have awesome compatibility as well.
Also riva128 cards did come in PCI form as well (I have a couple stashed) , so it is still an option 😀
But beware, the native win3.11 riva128 driver although speedy it can lead to serious system instabilities, I found that the hard way 🤣 .... s3 cards are fine though
Reply 16 of 20, by Pippy P. Poopypants
S3 cards are definitely the choice if you want very good compatibility with DOS games/apps and Win 3.1. The RIVA 128/ZX cards would be a close second in my book, along with older Matrox cards.
Not sure if serious or just trollin, but standard DOS VGA performance on those things is quite painful, especially with mode X games and apps. Of course, you can use the renutil utility to map standard VGA resolutions to VESA resolutions but it doesn't work with mode X.
GUIs and reviews of other random stuff
Вфхуи ZoPиЕ m
СФИР Et. SEPOHЖ
Chebzon фt Ymeztoix © 1959 zem
Reply 17 of 20, by nforce4max
Have but one question. Since I had little luck tracking down a pci version of the riva128 would a pci version of the riva tnt offer the same or similar compatibility? Plus the riva tnt has some sentimental value as well.
Reply 18 of 20, by noshutdown
what os do you use? most nvidia cards have good compatibility in dos so i guess tnt would be ok, but i doubt there would be any driver for windows3.1
Reply 19 of 20, by Pippy P. Poopypants
TNT should be fine for such applications. Only in extreme cases would you require SciTech Display Doctor.
Windows 3.1 drivers exist for the TNT, but they are quite buggy and crash-prone. And you are for the most part stuck with the 60 Hz refresh rate.
Windows 3.1x & Windows NT 3.51 Graphics Card Drivers Collection
Вфхуи ZoPиЕ m
СФИР Et. SEPOHЖ
