Windows 7 and CD audio
First post, by leileilol
I can't seem to find a straight answer to get native CD audio working with Windows games that use mixed mode discs for music tracks.
Real CDs, not images.
Reply 1 of 14, by silikone
It should work by digitally feeding the sound card without any special cables. I have no trouble getting CD audio to work, but there is a bug which I believe affects everyone with Windows 7. Tracks do not loop when they're supposed to.
Are you able to play the tracks with Windows Media Player?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
Reply 2 of 14, by leileilol
Yes, Windows Media Player works with the tracks
Reply 4 of 14, by leileilol
unfortunately _inmm.dll doesn't work for frogger, even when force patching it
Reply 5 of 14, by Procyon
I found out that the music of most games work if the CD is in the 1st optical drive, that also means first if it is a virtual optical drive.
That way I got the music of Battlezone, TDR 2000, Jedi Knight and a bunch of others working, some still refuse to work though. 🙁
Reply 6 of 14, by Jorpho
Do you see the drive's activity light blinking at all while the game is being played?
Reply 7 of 14, by HunterZ
This is probably the big one.
I wonder if running with Wine under Linux might help (if that's even an option for the OP)? Those 16-bit Windows 9x era games seem to like Wine a lot better than Win Vista/7.
Reply 8 of 14, by RoyBatty
There seems to be a bug in windows 7 regarding mixed mode discs when using certain software... many times it see's them as data or audio only and not a mixed mode CD. I've had this issue before myself. I tracked it down to being daemon tools 4.xx, uninstalling it fixed the issue for me. Still the looping problem however...
Reply 9 of 14, by totalizator
Thank you! Now I can play Ignition with music on Win7 64.
Reply 10 of 14, by Gamecollector
Frogger isn't working with CD-audio even in Windows Xp.
It looks like the WinXp MCI implementation is bugged/incomplete...
Reply 11 of 14, by DracoNihil
I also have problems getting CD AUDIO to work in Win 7. It goes like this: The track plays fine, but then it never bothers to switch tracks or repeat the same track. And sometimes it does manage to play something next or loop what it was currently playing but then it skips every other second...
Uprising 2, Redline, and Thunder Brigade are the games I have the most trouble with getting the CD music to work...
― Κυνικός Δράκων
Reply 12 of 14, by RoyBatty
Microsoft broke MMC, all there is to it.
Reply 13 of 14, by Malik
Ermmm...just one question : does an image made from the Frogger cd work with cd audio?
I too faced no-cd-sound-if-not-using-1st-cd-drive-letter before, but can't remember which system it happened, but sure it was pre-7. I think it even happened in Win9x.
Reply 14 of 14, by mr_bigmouth_502
I managed to get CD Audio working for Warlords 3 Darklords Rising on my Win7 laptop by ripping the disc to a cue/bin image and assigning the letter of the virtual drive to D:. To get the game installed however, I first had to install it on a machine running XP and copy over the files.
