486 help
First post, by j'ordos
Hello all,
I've recently acquired my first 486 since childhood! 😀 The system works (came with windows 3.11) except for the FDD. There's no onboard IDE or FDD controller, everything is connected to the ISA controller card. When I connect the FDD properly I get a floppy disk error during POST, when I connect the cable upside down the floppy light burns continuously and the system boots fine. I already tried a different floppy drive and it made no difference (though I didn't bother testing it in a working PC so it may also be broken). The jumper settings on the ISA card are correct AFAIK (I'll post a pic when I can though) so I guess the controller card is broken, unless I'm missing something else, like a bios setting/jumper on the mainboard? Unfortunately I have no idea what model it is, nor how to get into the BIOS setup. According to the ami bios string the board is made by Lucky Star. It has a bunch of 16bit ISA slots and one 8bit slot, 4 32-pin memory slots containing a whopping 4MB RAM. the processor is a TI486something (forgot th rest), there's also a coprocessor. One of the chips says 386 BIOS though. Anyway I'll try to post a picture so someone might actually help me in IDing this board but I couldn't wait posting. 😊
Reply 1 of 37, by badmojo
You've got yourself a fancied up 386 there my friend, not a 486. That chip has some 486 features but isn't the real deal - still a cool machine for early 90's games though! Have you tried all combinations with the fdd cable? Remember that you can flip the end that plugs into the ide controller as well. I must have installed a thousand floppy drives in my life and I don't remember ever getting one right the first go.
And definately have a look at the bios settings and make sure the machine is looking for the right sort of drive. It's usually the delete key to get into the bios.
Good luck!
Reply 2 of 37, by j'ordos
bah that seller totally ripped me off! Good thing it was free then though. 😀 I'll try switching that one as well, haven't tried that for some reason. Is it possible for an old motherboard such as this one that it doesn't have a BIOS setup utility? There's no mention of a 'press >key< to enter BIOS' during POST. thanks for the reply!
Reply 3 of 37, by HunterZ
I believe the 386DX-33 I had back in the day had a BIOS setup, so yeah they were doing them around that time.
I do remember some machines having a setting for an alternate (Japanese?) type of floppy drive. You also didn't mention whether it's a 5.25" or 3.5" drive, or high/double/low density, and the controller probably cares about that.
If you have a cable that can connect to 2 FDDs, you might also try switching which connector you're using for the problem drive.
Reply 4 of 37, by nforce4max
If all else take a picture of the back of the drive and the cable connector then post it here. There should be plenty of people ready to help you.
Reply 5 of 37, by j'ordos
Thanks for the replies, embarrassingly it turns out that the end of the cable that goes in the controller card was upside down 🙄 . Delete key activates the BIOS setup. Sadly I couldn't find a model number for the mainboard in there. The processor is a 486 DLC-40. Once I find my camera I'll upload some pics of it! Thanks again for the help so far!
Reply 6 of 37, by j'ordos
Well it took some time but I finally took some pics of the mainboard. Any help Id'ing this would be grand 😀
I found schematics for the ISA controller card here: http://stason.org/TULARC/pc/hard-disk-floppy- … AT-inte-63.html. Before I go ahead and try, is there any reason this card would not support CDROM drives?
Lastly, given my limited ISA gfx & soundcard collection, does anyone have any recommendations for this system? I have the following two gfx cards:
http://www.vgamuseum.info/index.php/component … logic-cl-gd5420
http://www.vgamuseum.info/index.php/component … ital-wd90c30-lr
for soundcards I have these three:
a FSSC-CS2.1 3D sound with a crystal CX4237B-XQ3 chip
a media magic card with an Analog Devices AD1846JP soundport chip
and lastly an ESS Audiodrive ES1868F
    2.29 MiB
    158 downloads
Reply 9 of 37, by MaxWar
A few rules of thumb i use to get my FDD to work on the first try.
These are common knowledge but maybe might help.
-the middle connector in the floppy cable is for 5.25 drives
-The extremity connector with the crossover goes on the 3.5 drives
-On the controller board you have have pin 1 and 2 of the connector written on the PCB, the red wire of the floppy cable goes on this side.
- When there is a pin missing in the middle of the connector on the floppy drive, the notched side of the floppy cable goes opposite of the missing pin.
When it still does not work i try to reseat the ISA controller and usually try changing slot.
This being said I have a 486 board that will not detect any hard drive no matter what hard drive and what isa controller or cable i use, the FDD works though. I think my board is simply defective, it suffered some serious battery leaking damage...
Good luck
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 10 of 37, by j'ordos
Thanks for the advise, the floppy is working now though. Badmofo was right in suggesting that the end at the IDE controller could be reversed. 😀 I'm now about to add a CD-ROM drive (taking it to the next level 😏 ) but since there's no mention of CDrom devices on the configuration page of the ISA controller card I was wondering if it is even supported/possible?
edit: that's right, I noticed I have a barrel type CMOS battery on this board. Should I be worried? It looks fine, though I remember reading those batteries were prone to leaking?
Reply 12 of 37, by FGB
The Ti486DLC is a Cyrix 486DLC clone. It's basically a pimped up 386 with 1KB L1 cache and the 486 instruction set. Running at 40mhz the speed is quite nice and competes with entry level 486 CPU's up to the DX-33, depending on the game/software used. If you pair it with a decent ISA graphics card (e.g. a Tsengs Labs ET4000) it's a nice and fast machine for the classic DOS games.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
Reply 13 of 37, by sliderider
That's wrong, actually. The TI version has 8kb cache.
Reply 14 of 37, by FGB
Nope. Your statement is wrong.
I have the Ti486DLC CPU myself:
http://www.amoretro.de/2012/03/386-486-mainbo … 4c87dlc-33.html
The DLC's have 1KB L1 cache. Maybe you mixed it up with Ti's later "SXL" which had 8KB cache as well as the original 486 CPU's of the 486 platform.
Reply 15 of 37, by sliderider
FGB wrote:
Nope. Your statement is wrong. […]
Read please and tell me how much cache this page says it has. I also have several TI 486DLC's.
http://www.cpu-museum.de/?m=Texas+Instruments&f=486DLC
The site you linked has incorrect information.
Reply 16 of 37, by j'ordos
It holds the BIOS values fine so far.
The Red Hill cpu guide also lists the DLC40 as having 1k L1 cache (http://redhill.net.au/c/c-4.html)
edit: though it's a cyrix DLC40 that's on that page and not a TI one I see now
Reply 17 of 37, by FGB
No, sliderider, the 1993 Ti is a 1:1 Cyrix clone with 1KB of cache. Period. I have this from first hand experience. And 99% of the websites list it with 1KB as well.
We should better concentrate on helping the thread opener because he has a really nice setup there.
Reply 18 of 37, by Anonymous Coward
TI started out making exact copies of the Cyrix 486DLC (TI 486DLC), but later they started producing an 8kb version (TI 486SXL). This annoyed Cyrix, which lead to the termination of their contract.
Reply 19 of 37, by FGB
Yep, that is exactly what happened back in the day and I'm happy someone remembers this correctly, although the contract termination didn't last long or just applied to the DLC, I don't know the details.
This is btw. what I wrote earlier:
