SquallStrife, thank you so much for your effort. If I had two of the WS32 cards I would give you one for sure!
The disk contains a lot of tools (all in English language), including a super easy and straight forward configuration tool for a resource-management (hex adresses, irq, interface control, etc..) as well as very interesting programs to fine-tune the effect-processor of this card (dream SAM8905) and finally a graphical mixer interface with a routing map where you can program the volumes as well as the direction of a sound source (OUT or IN). There is even a global echo which can be deactivated.
Also very funny: A karaoke-program in Korean with circa 10 sample songs.. really funny.
There is also a tool called "okmode" where you can set all the soundcards MIDI modes. Set the wavetable to GS or MT-32 mode, for example. All very easy to configure. I think this card has also an intelligent MPU-401 interface because you can switch the external midi connector from "normal" to "uart" mode.. but i did not try it out because i don't own a mt32 (shame on me, I know 😉 ).
The "ectset" tool for the effect-processor is also very very useful and also the very only tool for the SAM8905 I know (the Maestro 32/96 for example does also have the SAM8905 but doesn't allow the user to finetune the reverb and chorus effects and as a result the Maestro 32/96 tends to be a bit an the "dry" side compared with the MIDI-Sound on an original Roland module like SCD-7).
In detail you can apply the following settings and set the effect strength form 0 to 15 in each effect:
Reverb:
Room1
Room2
Room3
Hall 1
Hall 2
Plate
Delay
Panning Delay
Chorus:
Chorus 1
Chorus 2
Chorus 3
Chorus 4
Feedback Chorus
Flanger
Short Delay
Short Delay Fall Back
If you set any Reverb and Chorus mode the values are stored in the EPROM of the card.
You can even apply the reverb settings to the FM chip of this card (OPL3 compatible) BUT .. in general the FM chip doesn't sound so good. It sounds quite different from the original Yamaha one (at least in doom).
But the Midi sounds really really great. Undoubtly there is the Roland Sound Canvas Soundfont in the ROM Chips, just like suspected. It also sounds very vivid and very punchy if you fine tune the effects and give the chorus a bit more juice.
But that's not all. I accidently booted from a floppy disk with no autoexec.bat and started doom. The card plays out of the box!
Not init required for General MIDI Wavetable and SoundBlaster digital sound. Just nothing!
I really like the card for that. So when you have the chance to get the Oksori WS32 with the daughterboard attached - do so!
You won't regret it as you get the original Roland Sound Canvas Soundfont and a tool to program the Effect Processor just for your preferences / needs. I think the potential of this card is really unknown in the US and also here in Europe as it is a card targeted on the asian market only. But this doesn't prevent it from being awesome!
Cheers,
Fabian
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
