First post, by Stojke
I bough a full pack GUS Max v2.1 with all papers, box, and everything a few days ago for something like 5$, as well as AWE64 gold with all cables and stuff...
And I cant seem to get GUS to work in Windows 2000, and also in DOS.
Windows does not detect it, Dos says the card is busy when it tests it.
I have set the IRQ to 11 and DMA to 1.
I have the original disc.
Reply 1 of 12, by elfuego
Plug out everything else before connecting GUS 😀 Otherwise, check in this forum whats the default fail-safe setting for GUS and use that. Also make sure your PSU has some juice at -5V branch which is required by some ISA cards (not sure bout GUS).
Reply 2 of 12, by Stojke
Ok, i had one NEC USB 2.0 card in it, im gonna take that out.
The -5 Rail provides 0.3A.
I dont know where to start searching for that, thats why i opened this topic, i guess some one could point me to the usual problems right away.
Reply 3 of 12, by elfuego
Google on this site 😀 And always post your complete hardware configuration.
Reply 4 of 12, by Stojke
Ok i will, and here is my configuration:
Dell OptiPlex GX1
700MHz PIII
512MB SD RAM 133MHz
40GB Western Digital
3GB Samsung
Integrated Ati Rage AGP2X 8MB
Reply 5 of 12, by megatron-uk
I doubt you'll ever get the GUS working in Windows 2000 - I personally wouldn't bother. There was a beta driver released for the CS4231 codec believe, but the GF1 (the bit which does all the sample loading/playback goodness) wasn't supported beyond 95/98.
Try *all* the combinations of IRQ and DMA - the GUS can be quite picky; you may have to disable serial and parallel ports in the BIOS to make it happy!
https://www.target-earth.net
Reply 6 of 12, by Stojke
Ok, ive set the HEX to 220
and CD IRQ to 10, DMA to 1, etc etc.
The GUS is detected now and the program gives it a PASS on every test, but still NO SOUND!
Windows doesnt even detect it (says unknown hardware on IRQ11), plus after driver install i had to restore win.com...
Any one?
[Edit]
The MIDI is detected, says Single Devices UltraSound midi output port.
But there is nothing detected on Device manager nor on Sound options for playback and recording.
Reply 7 of 12, by megatron-uk
Seriously, I can't ever see it working. The best/latest driver released was a beta directsound compatible version - like I said, it didn't support the GF1, only the CS4231 chip.
Stick with Dos, or Win95/98 if you want to utilise it properly.
Reply 8 of 12, by Stojke
This is Windows 98/DOS 7.1
The demos load into memory, the program displays them playing, but no sound.
Reply 9 of 12, by Stojke
Any one?
Reply 10 of 12, by Stojke
Lol, it works under windows 95 MS DOS.
That means it has something to do with Windows 98 or something... Im gonna test OPL3 too, maybe my windows 98 is defected.
[Edit]
Derp, seems it was the serial ports. Works on Win98 too now.
Striving midi is amazing!
The volume is a bit ear busting, but i can handle it.
Reply 11 of 12, by megatron-uk
I did reccomend disabling the extra ports 😉
Try therain.mid - you may also want to get hold of the larger 'Pro Patches Lite' sample set - it's a good improvement on the basic samples included on the Gravis install floppies.
Reply 12 of 12, by Stojke
I have the CD only, 100+ MB of stuff on it. Where should i search?
Also, when it comes to memory, can GUS handle a 1MB module as 512? Thats all i have (from a S3 GPU).
